Stickied: 4L70E - worth a look? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 02-17-2012, 10:06 PM
Dan Fahey's Avatar
Dan Fahey Dan Fahey is offline
Dan Fahey is an unknown quantity at this point
Default Stickied: 4L70E - worth a look?
GM has introduced a 4L70E transmissions..
Is this a good replacement tranny fro the 4L60E?
Better to upgrade the 4L60E
D
Old 02-17-2012, 11:01 PM
Bowtie 9C1LT1 Bowtie 9C1LT1 is offline
Bowtie 9C1LT1 is an unknown quantity at this point
Default
waste....they dont even have a vette servo. I believe it has the 5 pinion planetaries. Either way they are going on 6 yrs old.(so they have been out for awhile)Just build your 60 up better. IMO
__________________
96 BBB CAI spintech ss304 exhaust,Tri-ys, Hotchkis everywhere,3:73s with eaton, 1.6cc/ls2 springs, black imp rims,dennys d-shaft,
98 Lumina 9c3, beater sold!
06 Impala magnaflows k/n
96 9c1 gone, not forgotten
96 BBB sold
ISSCA #2461
  #3
Old 02-17-2012, 11:15 PM
wytltng's Avatar
wytltng wytltng is offline
wytltng is on a distinguished road
Default
Why not upgrade to a 5sp allison?
  #4
Old 02-17-2012, 11:50 PM
grandpas wagon grandpas wagon is offline
grandpas wagon is an unknown quantity at this point
Default
Can you expand on this? Sounds interesting. Experience, links, conversion, etc?
Forum search and Stickys came up empty.
__________________
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
All my posts contain 100% recycled electrons.
  #5
Old 02-18-2012, 12:21 AM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
I doth thinketh he was being sarcastic
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #6
Old 02-18-2012, 06:57 AM
wytltng's Avatar
Default
Not true. In this case. I can be at times.
I have a 5sp allison in my 2500HD. It bolts right up to the 8.1 & has its own dedicated computer. I know these trans could handle the torque an power we want to put behind them.
I would be interested in seeing if these would work.
Maybe Shane has some insight.
I know they are not cheap used.
  #7
Old 02-18-2012, 07:14 AM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is offline
Navy Lifer is an unknown quantity at this point
Default
GMPP catalog - page 152 to 156 gives full details.
I think 4L70 was designed for use behind LS engines--the crank/flex plate position difference may prevent it from being a bolt-on for the GenI/II blocks--there is an adapter package that provides the ability to use later GenIII/IV transmissions on conventional small blocks, including LT1, but it's not 100% clear in the way it's listed as far as the 4L70.
I'm thinking the sheer size of the Allison 5-speed may prevent it's use in the car, without cutting out the tunnel/floor at the firewall and making a new one. Trans crossmember position would probably be different, too, as well as a number of other things--and just like the rest of the Gen III/IV transmissions, an adapter setup would be necessary.
The 4L70 is rated for 495# torque--it should handle just about anything that can be thrown at it.
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
  #8
Old 02-18-2012, 07:24 AM
Mr pogo's Avatar
Default
3 reasons why not for b-bodies.
too big
weighs too much
high parasitic power loss
not to mention lack of performance converters and gearing may not be optimal for performance and other things along that line.
__________________
  #9
Old 02-18-2012, 12:37 PM
cahall cahall is offline
Banned
cahall is on a distinguished road
Default
The 4L70E has no performance advantage over a 4L60E. I update my "Race" and "Pro Race" 4L60E's with certain 4L65E parts to add strength. As far as an Allison? Great TRUCK transmission, but as already stated, it's too big and heavy to have any benefit in a performance vehicle. This closely related the the misconception that a 4L80E is a good performance transmission. We had a few hard headed customers 15 years ago that thought the 4L80E would be better than a 4L60E. EVERY car we built them for slowed down ATLEAST 2/10's in the quarter mile. We ended up swapping most back to '60E's...Or the customers got so disgusted that their cars were now turds that they sold them.
Frank
  #10
Old 02-18-2012, 01:18 PM
Jeff Green Jeff Green is offline
Jeff Green is an unknown quantity at this point
Default
Frank
DEAD ON!! I use some 65 and 70 parts in the 60 but thats all you need.
I guess only racers think about power loss but if you care about ET then you better care about power loss. It's easier to not have to figure out how to make more power when you can reduce power loss behind the engine. A 4L80E eats power and you cant make up 2 tenths in a better 60 foot launch so even a slower 60 foor by a little will result in a faster ET in the full run.
Ramdom thoughts but thats one reason a 60 is still in my car.
__________________
LTX Aluminum LT1 block engine
Most HP from an OBD1, 1400 plus horse power
Fastest 4L60E
Fastest Impala with everything still in it, 4520 pounds no weight taken out. 9's in the 150"s
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
