#11
When mine wouldn't open I stuffed a rag between the grill,and bumper pad. This created enough upward pressure to pop the hood when I pulled the lever.
| Sponsored Links | ||
Advertisement | ||
#12
once you remove grille then??
__________________
![]() There's a reluctance to confront reality and a desire to soften unpleasant realities |
#13
PM sent
__________________
1995 Gold Caprice Wagon 1991 White Caprice Wagon 1991 Olds Custom Cruiser Wagon Sold 1995 RMW under construction 2004 Impala SS 2012 Chevy Terrain SL2 1974 BD-5T WIP |
#14
you dont need to take the grill off . lay on the ground in front off the car . use your hand to feel around the latch . You will feel a lever or a switch , push to the right . Hood will pop right up . Surprised the s hit out of me when I had the same problem .
__________________
96 Impala SS BBB vortech v1 supercharger 112k mi. 07 Escalade Black on Black 75k mi. |
#15
thanks GoldSSWagon got it but now the little thing the cable sits in popped off
__________________
#16
If you pull on the cable housing,as long as it is unattached. The hood should open.If not,then snake your finger in behind the latch.Find the release lever and pull it towards you.
#17
sawzall
__________________
I tint tail lights and fix bad bondo! |
#18
i got it open i just gotta get that little clip to make it work correctly
__________________
#19
Are you referring to the clip on the bottom of the actuator arm on the latch itself?
__________________
1991 OCC upgraded LO5, wrapped headers, dual Flowmasters, 3.23 posi, drop spindles & springs, Stainless full moons, 255/60/15 R, 215/70/15 F, Recaros, Nardi/MOMO SW w/QR, Pioneer DEH P77DH 1992 OCC now with 5.7 tbi For a parts list, check Plenty of good parts Old mechanic's saying: If it doesn't work, hit it with a hammer...if it still doesn't work, use a bigger hammer...if it breaks, it needed replaced anyway. |
#20
on the latch that's bolt to the radiator support. there's a hole on the bottom where u can stick ur pinky finger in. u'll feel a solid object. try to push it toward the driver side of the car. if it's a lil subborn have someone push down on the hood slightly not to put a dent and it should push over a bit easier then pull the hood up and unlock the hook.
to prevent other's from opening your hood using this method seal up that hole. or wrap ur hood shut in chain behind the hood.
__________________
(95 caprice classic tow package! 3.73, 1.6RR, beehive springs, HOTCAM, airbox delete, K&N air filter, removed mechanical fan and install electrical fan, tuned Last edited by defdaboss; 03-22-2012 at 02:52 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
