Turn Signal Stuck ?? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 03-24-2012, 09:51 PM
Coolwazabi's Avatar
Coolwazabi Coolwazabi is offline
Coolwazabi is on a distinguished road
Default Turn Signal Stuck ??
So I just got doing the hockey puck mod "which is breezy" and when it drive it around and suddenly my right turn signal is stuck. The light come on but it doesn't flash. The hazard lights work just fine along with the left turn signal. Ideas ?
__________________
Flowmaster 50 Series w/ 4" Tips
DDM Tuning 55w 5000k HID's
15" Custom Audioque HDC3, 35hz
2x Audiopipe 1800d's
Kenwood KDC-X996
Big 3 Upgrade
5901 Viper Alarm w/ Remote Start
1995 Chevy Caprice 4.3L L99
Nashville
Old 03-24-2012, 09:59 PM
The Fooser Guy's Avatar
The Fooser Guy The Fooser Guy is offline
The Fooser Guy is an unknown quantity at this point
Default
On the interior side of the firewall (inside the car), about where your left foot sits (but up a little higher) are two, round, silver relays (about the diameter of a half-dollar). Pull them out and push them back in.
Try the turn signals.
If that does not work, swap the relays and see if the problem goe to the left turn signal.
If it does, replace the defective relay (car parts store).
HTH
__________________
The Fooser Guy
"Diagonally parked in a parallel universe."
Originally Posted by thebigbadWOLF View Post
Tested a coil by listening to MR.WOODS... ****ing coil WORKS just fine.... ass hole
  #3
Old 03-25-2012, 01:15 PM
AZ Roadmaster's Avatar
AZ Roadmaster AZ Roadmaster is offline
AZ Roadmaster is on a distinguished road
Default
Take the hocky puck out, turn it 1/4 turn and re-install it, this should fix it!
__________________
[/SIGPIC]92 RMS, daily driver, project car
  #4
Old 03-25-2012, 02:11 PM
Coolwazabi's Avatar
Default
Pulled both 1 out then both worked. Switched them and then none worked. There both different. Any idea what the model is suppose to be?
__________________
Kenwood KDC-X996
Big 3 Upgrade
Nashville
  #5
Old 03-30-2012, 01:11 AM
shudahadaV8 shudahadaV8 is offline
shudahadaV8 is on a distinguished road
Default
I think that one is for the turn signals and the other is for the emergency hazards and I don't remember which is for which, but if you pull one then the other you can quickly tell. I have a 95 "B" and always thought that both left and right turn signals share a single flasher (can't turn both ways at once). So if the one side flashes and the other doesn't ... well, that's odd. Turn signal switch ??
  #6
Old 04-28-2012, 09:06 PM
cavav8r's Avatar
cavav8r cavav8r is offline
Junior Member
cavav8r is on a distinguished road
Default
HTH
nice!!! had the exact same problem (no hockey puck mod though) right turn signal sticks. swaped the relays and they both worked fine. here's the interesting part though. after swapping the hazards still work, but flash fast now. doesn't matter though, just glad it did the job! thanks guys!!!
__________________
'96 SS
200,000 Miles
Currently in Phase
Jasper 383 and XMSN, 3.73 Gears
  #7
Old 04-28-2012, 10:08 PM
SimplyTheBeSS's Avatar
SimplyTheBeSS SimplyTheBeSS is offline
SimplyTheBeSS is on a distinguished road
Default
Fooser is the smartest Guy I know!
__________________
1994 SS - GRAIL President & Webmaster, St. Louis, MO
View our Tech/Guide page for everything from your basic oil change to Manual transmission swaps!
  #8
Old 04-29-2012, 01:12 AM
4x4high 4x4high is offline
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
When a flasher goes bad the lights will either not blink at all or they blink super fast and i've seen the same thing when a bulb is bad (although if you checked the bulbs with either the turn signal or e-flasher and they worked it's not a bulb).
Forum Jump
(c) 2007-2011 Impala SS Forum
