Sub Amp and wiring questions for two l7's - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > Audio/Video/Security > Audio
Thread Tools Display Modes
  #1
Old 05-27-2012, 12:35 PM
aives245 aives245 is offline
Junior Member
aives245 is on a distinguished road
Default Sub Amp and wiring questions for two l7's
I just got 2 12inch L7's in a ported box and i was trying to figure out how to power them. The subs are two ohm and so if i wanted to power them with a mono channel amp and use a bridging wire to connect the subs i would want to get a 4 ohm amp correct?
And as for powering those since they are rated a 3000 watts together an 1500 rms, also together, i should be able to use a 3000 watt 4 ohm mono channel amp and power them both correctly and sufficiently. Right?
Old 05-27-2012, 12:39 PM
Junior Member
Default
And wire it like this, what wattage amp would be proper?
Click image for larger version
  #3
Old 05-27-2012, 01:09 PM
WalledLTZ WalledLTZ is offline
WalledLTZ is on a distinguished road
Default
that would be series wiring for the 4 ohm load.
youd be be in a amp way over necessary to get a 3k watts at 4 ohm.
ideally you want to parallel those down to a 1 ohm load.......your mono 3k watt varieties have just expanded.
so you want a 2500- 3k mono at 1 ohm
  #4
Old 05-27-2012, 01:14 PM
Junior Member
Default
Ok, I didnt understand any of that.. Im new to the whole audio thing. so this is all very confusing.
But why do I want to get them down to 1 ohm, when the subs are 2 ohm?
  #5
Old 08-25-2012, 12:31 PM
bear94 bear94 is offline
Junior Member
bear94 is on a distinguished road
Default
ohms are resistance so the lower the ohms the less resistance
  #6
Old 08-25-2012, 12:43 PM
Junior Member
Default
i believe if you wire them in a parallel you will bring them down to a half ohm i think i cant remember if its half or one ohm any way thats what you want then match them to the kicker 2500.1 and they will knock.
  #7
Old 08-25-2012, 05:32 PM
Crtlv's Avatar
Crtlv Crtlv is offline
Crtlv is on a distinguished road
Default
you have two ways to go.
first you can connect each sub the following way
on the back of your l7s you have two red and two black connectors and one set has a dot in the center IE red with dot black with dot
you connect the black with dot to red no dot
do this to EACH sub seperately
then connect the wires that connect to your amp to the red with dot and black no dot,that will step up your OHM load and make each sub 4 ohm and if your using a mono Amp when you tie the two subs together the amp will see a 2 ohm load.
now your going to need a amp capable of putting out 3000k RMS to properly push these and IMHO there isnt many in a afforable price range for a single amp that will do that.Dont believe what you read on some of the cheaper Performance teknique and the like amps ive metered these before and they are WAY over rated in every sense of the word.
The way i would go is the following
connect the reds togehter "red with no dot to red with dot"
and blacks together "black and black with dot"then connect your positive speaker lead from your amp to any red one on each sub and your negative connector to any of the blacks
now you stepped down the ohm load and the subs will be at 1 ohm
then go and get TWO decent amps rated for a 1 ohm load at 1k or better
JL audio some kicker and some sony i beleve will do what you want.
Its more efficent easy to set up and IMHO will be more affordable in the long run.The two amps wont heat as much or as fast as the one amp and you can get way better quality for a few bucks more than the single amp plus it just looks dammed cool !
hope that explains it
  #8
Old 08-26-2012, 11:59 AM
305classic's Avatar
305classic 305classic is offline
305classic
Default
^^^ that was to much for me to read so sorry if im reanswering anything but L7's are what called dual voice coil, look it up on google and youll see exactly what i'm talking about. also just find a 1,000 watt 2ohm capable mono amp and youll be fine. or if you want the 1,500 watts just find two 750 watt amps that are capable of 1 ohm.
  #9
Old 08-26-2012, 04:46 PM
Coolwazabi's Avatar
Coolwazabi Coolwazabi is offline
Coolwazabi is on a distinguished road
Default
sorry to say but you messed up getting dual 2 ohm woofers.. your going to have to find a powerful amp that does 1500 ish @ 4 or 1500@.5 and beefing up your electrical and making sure the amp can handle .5ohm.
you can get a 2 channel amp that bridges both channels to 1500@4ohm. Easy as that.
__________________
Flowmaster 50 Series w/ 4" Tips
DDM Tuning 55w 5000k HID's
15" Custom Audioque HDC3, 35hz
2x Audiopipe 1800d's
Kenwood KDC-X996
Big 3 Upgrade
5901 Viper Alarm w/ Remote Start
1995 Chevy Caprice 4.3L L99
Nashville
  #10
Old 08-27-2012, 11:00 AM
Nor-CalSS Nor-CalSS is offline
Nor-CalSS is an unknown quantity at this point
Default
This might help you.
http://www.kicker.com/dvc_wiring
__________________
95 DCM Imp SS....Daily Driver 98k and counting
72 Cutty............Weekend cruiser.
Forum Jump
(c) 2007-2011 Impala SS Forum
