Moser Axles with no hub?? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 06-16-2012, 11:47 AM
CheapSS CheapSS is offline
CheapSS
Unhappy Moser Axles with no hub??
I just recently bought all the parts to rebuild my rear end on my Impala to include Moser axles. After everything was replaced I was getting a vibration at cruising speeds. So I took it to Firestone and they balanced my tires but I still had a vibration. Firestone told me they thought my problem was in my rear end. They also showed me that my wheel bearings had a little play in them. So I went back to the shop that installed all my parts in my rear end and they found nothing wrong. They advised that I take my car to a different place for high speed balancing that balances the wheels on the car. So I did..they found my problem to be that the Moser axles don't have the centering hubs like stock axles do that stick out and assist in centering the wheel. Without them it allowed the wheel to be UN-centered on the axle which in turn caused my vibration problem. I still have stock rims and so I should not be having this problem. I'm just wondering has anyone else had this problem and if so how was it handled.
Old 06-16-2012, 02:15 PM
Choo's Avatar
Choo Choo is offline
Choo is on a distinguished road
Default
Are these the ones you ordered:
http://www.moserengineering.com/axle...sc-brakes.html
You can try to loosen the wheel nuts and then retighten them by hand before torquing them dowm.
  #3
Old 06-16-2012, 02:18 PM
CheapSS
Default
Yes that is the same part number but they look different from that picture that is on there site. But yes that is the part number of the ones I got.
  #4
Old 06-16-2012, 05:07 PM
crerus75 crerus75 is offline
crerus75 is on a distinguished road
Default
Wheels can be either hub-centric (centered by the hub) or lug-centric (centered by the lug). I don't know if, over time, you will be able to keep your wheels centered on those axles with just the lugs if they do not have a centering ring on the hub. The only recommendation I've been able to find is to torque the wheels with the vehicle in the air so that the conical seats on the lug nuts will center the wheels. Because the factory wheels are not lug-centric, you might have a vibration no matter how careful you are, and they might shift and loosen no matter how much you torque them. For now, all I can recommend is to torque them with the car in the air and to check the torque on the stud frequently. I hope someone chimes in with a better solution.
  #5
Old 06-16-2012, 05:25 PM
CheapSS
Default
The shop that does high speed balancing tried to center it but told me that it was a hit or miss deal because the it was supposed to be center by the hub. I've already got a authorization to return the Moser axles but was hoping someone else has had this problem and could help me. I would rather have Moser axles than have a stock replacement but it looks like that's what I'm going to get cause I can't deal with the vibration.
  #6
Old 06-16-2012, 06:10 PM
DonL DonL is offline
DonL can only hope to improve
Default
I'm running Moser axles in my car. I does take a little extra time when you tighten the wheels, but it's not difficult. Tighten the lugs nuts by hand a little at a time and let them center the wheel. Then I give the wheel a little wiggle and tighten any loose lugs. Put a good torque on them in the air and a final torque them on the ground.
__________________
2013 ISSCA NATIONALS - Concord, NC
Get Strapped in for one heck of a Ride!!
Are You in?
  #7
Old 06-16-2012, 10:37 PM
stratman stratman is offline
stratman is an unknown quantity at this point
Default
Hmm I'm interested in hearing more about this as I was thinking about also going to Moser axles soon... So if I'm understanding it right the Moser's have a completely flat wheel face and no center hub, can more confirm this because if so I'd probably also lean towards just stock replacements unless there is another forged aftermarket alternative that have the center hubs?
  #8
Old 06-16-2012, 10:38 PM
CheapSS
Default
WOW!!!!! So everytime you buy new tires, rotate them, do brakes, etc you have to do this!!! WOW!!!
  #9
Old 06-16-2012, 11:04 PM
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka is an unknown quantity at this point
Default
Originally Posted by stratman View Post
........ So if I'm understanding it right the Moser's have a completely flat wheel face and no center hub.........
My Mosers have the centering hubs........
KW
__________________
1996 BBB SS, 398ci SR
1995 DCM SS, 355ci
  #10
Old 06-17-2012, 12:44 AM
Default
There we go, thanks for chiming in KW. I'm thinking its those particular axles as I would think since Moser makes them as stock gm car c-clip axles an advertises as OEM replacements that they would have the centering hubs just like our stockers. I'd definitely like to hear more when you get through RMA'ing your axles with Moser
Forum Jump
(c) 2007-2011 Impala SS Forum
