94' Caprice Cluster stuck on 0 KM/h and Low acceleration power - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 07-07-2012, 04:33 PM
killerkid68 killerkid68 is offline
Junior Member
killerkid68 is on a distinguished road
Default 94' Caprice Cluster stuck on 0 KM/h and Low acceleration power
Specs:
94' Caprice
4.3 L
Sorry this is my first post i've done alot of reading and just registered tonight.
This all started yesterday morning in Ottawa i went to drive the old best and noticed low acceleration power it took forever to pick up and the cluster was stuck 0 and the trip was stuck at 0 as well as the kilometers read out on the car would not increase while driving. The check engine light is on as well on the cluster. Now the day before i just had the rad changed by a mechanic not myself but levels are all good with fluid and there is no overheating, i know this because the car ran great on the highway from Ottawa to Oshawa (400 km trip) just now and was still able to accelerate fine once the car reached above 30 km/h , I had no problem on the highway even holding the car at 130+km/h. Reason i know the speed i was using a speedometer on my phone the cluster still read 0 the whole trip has not worked since the problem started yesterday and the slow pick up is a constant issue since the problem occurred, Oh my cruise was working and now has stopped working since this problem has started. Guess what i am looking for is someone who has had this problem or heard of it and has a suggestion or two would be appreciated. All i could think of is a sensor but not sure ?
Old 07-07-2012, 05:00 PM
cahall cahall is offline
Banned
cahall is on a distinguished road
Default
You can try a search for speedo not working. First thing you should do is get the codes read to see what is stored. You may have a bad VSS, VSS exciter ring, or wiring. If the computer doesn't see vehicle speed, the transmission won't shift.
Frank
  #3
Old 07-07-2012, 05:01 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
the transmission appears to be in limp home mode for whatever reason due to the radiator repair.
could be a fuse, wiring harness not reconnected after the repair or even a ground wire left off.
knowing the fault code could help pinpoint the issue however yours requires an obd1 scanner because the jumper trick doesn not work to pull codes.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #4
Old 07-07-2012, 05:04 PM
Junior Member
Default
thank you i will pull the codes just hope its worth fixing this car is a pain and a tiny engine in it seems hardly worth it
  #5
Old 07-07-2012, 05:08 PM
Mr pogo's Avatar
Default
take it back to the shop and tell them how it started after they replaced the radiator.
there are grounds on the side of the radiator shell and drivers side head by coil altho offhand I dont know where the trans ground is sourced.
__________________
  #6
Old 07-07-2012, 05:20 PM
Junior Member
Default
even though the problem started a full day after the rad job? the car was working great for a day after. but none the less i need to read the codes
  #7
Old 07-07-2012, 05:52 PM
Junior Member
Default
grounds around rad and driver coil see all ok it wouldnt be a speed sensor would it just picking brains until i leave for auto store, can't find a code reader for this model
  #8
Old 07-08-2012, 12:47 AM
Junior Member
Default
Frank
going to do code scan tomorrow just wondering if the pcm is a possibility
  #9
Old 07-08-2012, 10:07 AM
Banned
Default
It could be, but it's not the most likely cause.
Frank
  #10
Old 07-08-2012, 03:54 PM
Junior Member
Default
Frank
ok stuck no one can tell what code reader i need for this car i looked at the gm code reader but it says it will only do the 94 caprice 5.7l not the 4.3 so just wondering if ou knew of a brand of one or model that would work this car is hell
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
