9c1 not starting, is there a factory engine disable alarm? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Caprice
Thread Tools Display Modes
  #1
Old 07-30-2012, 06:51 PM
mickeyvex mickeyvex is offline
Junior Member
mickeyvex is on a distinguished road
Default 9c1 not starting, is there a factory engine disable alarm?
I just dropped off my 95 9c1 caprice at the body shop to get painted. It drove fine like normal but after they took off the doors, hood, trunk lid, bumpers and such, it would not start. They said it would crank but not turn over and ask me if there was an alarm of some sort that would be causing it not to start because it was disconnected. they haven't had time to look more into it because there's a lot of body work to do to get ready to paint. I figured I'd ask the experts here and see what you thought the coincidence of removing doors N such and having the car not able to start. thanks for any input.
Old 07-30-2012, 07:18 PM
fbi9c1 fbi9c1 is offline
fbi9c1 is an unknown quantity at this point
Default
9c1's do not have systems like that. Mine has a hidden kill switch but if that were the problem it would not crank. The most likely answer is that the shop disconnected something. Make them find it and fix it. Good luck.
__________________
Jim B.
'95 9c1, pcmperformance.com 93 tune, Dynomax Ultraflo catback, K & N box filter, LT4 KM, 160 stat, 3.08 Posi.
  #3
Old 07-30-2012, 08:04 PM
Junior Member
Default
Thanks! That's what i was thinking but needed to make sure.
  #4
Old 07-31-2012, 12:24 AM
coppcarz coppcarz is offline
coppcarz
Default
something they disassembled must have had a ground attached to it....I think one of the major 9C1 grounds hooks up to the fender
  #5
Old 07-31-2012, 06:25 PM
Junior Member
Default
Thanks coppcarz, im going by there tomorrow and will pass this info along to the shop
  #6
Old 08-02-2012, 07:56 PM
BlackDog BlackDog is offline
Junior Member
BlackDog is on a distinguished road
Default
Check the wiring harness behind your license plate area that runs down under the car. I believe it is for the fuel pump. I recall having the same issue when I disassembled my car for paint years ago.
Then, find another bodyshop, because if they can't figure out something so basic, good luck.
  #7
Old 08-03-2012, 06:59 AM
Goldmaster's Avatar
Goldmaster Goldmaster is offline
Moderator
Goldmaster is on a distinguished road
Default
Look for the fuel pump ground that attaches to the driver side trunk hinge support. Maybe they disconnected it or it came loose when they popped the trunk lid off. Listen for the fuel pump when you turn the key on to see if it's priming.
  #8
Old 08-03-2012, 10:08 AM
Junior Member
Default
Thanks blackdog and goldmaster! Great info!
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
