#1
I'm 10 miles into a 20 mile drive to work.
running 65 on a flat highway. Engine just shuts off. Coast to stop. turn key off , wait 30 seconds , turn key on and then restart. Less than 1 year old MSD New OPTI. Fairly new ICM. No check lights and no DTC's. and returned Ignition to stock , got rid of the Mallory 685. any thoughts ?
__________________
95 Impala , 96 Motor/PCM, Ported/Polished Heads - 2.02's / 1.6's, Custom LE Cam, Mike Harris FL Headers, 3.0" Duals, 3.73's with Auburn Posi, CAI and 3.5" MAF, BH Tune, 150 Shot, Custom Performance Tranny, Dual Snorkel Glass Hood and Front Bumper, DGGM. 2009 Pontiac G8GT
| Sponsored Links | ||
Advertisement | ||
#2
It could be so many different things. Read throught the many threads on here & start making your list of things to check.
fuel pressure, icm, coil, & opti harness just to name a few And yes, I saw you have a fairly new ICM. Did you use the heatsink compound with it? If not, I would start there.
__________________
1996 Impala SS 1995 Roadmaster Wagon 1972 Ford LGT 100 1973 Ford LGT 145 |
#3
Probably Spark or Gas related. If it was me.
1. Get a fuel pressure gauge and check your line pressure. See if you start seeing it drop off etc... 2. Clean all your ground connections (can't hurt) especially by the battery 3. Change fuel filter if it has been awhile (can't hurt) 4. Put in a can of Seafoam or approved equal (can't hurt) 5. Check to make sure your Opti is dry and that the Waterpump hasn't been leaking on it.
__________________
1994 SS - GRAIL President & Webmaster, St. Louis, MO
View our Tech/Guide page for everything from your basic oil change to Manual transmission swaps! ![]() |
#4
next time it dies.you shouldn't have any fuel pressure if its the ICM.also it usally take several min to cool down. then it will restart.the opti will give the same signs but start right back up.if you can have it scanned and see if your getting a weak signal from the opti.if so its ether your new opti or the cable going to it.
__________________
http://www.youtube.com/watch?v=GRqsOvpSxA4 President of SoFASST.com 05-06 1st place 94 class nationals 05 3rd place sound off 06 3rd place autocross also as seen on the ITT commercial 95 caprice wagon impala clone |
#5
None of the above suggestions have proven to be an issue.
It almost has to be electrical. The MSD opti has abuilt in cable that eliminares the old plug in cable issue. If it was fuel , the car would at least run rough for a few seconds, This is happening like the key was turned off. All engine grounds were repaired last year , after it was found several leads were broken at the cylinder head. so , the search goes on.
__________________
#6
Mine is doing the same thing. I put new CIA headers on and new 3" pipes all the way back and got rid of the cats. I had PCM reprogramed without the EGR and not using the rear O2's. I can drive the car and not have any problems for a couple of days and then...it just turns off. I don't have any stutter it just cuts out. If I leave it for a min. or two it restarts and runs fine. I have checked the fuel and it reads fine at both idel and in gear. The plugs are new and so are the wires. I have not checked the grounds yet. If I find it I will let you know. Good luck VF1000R.
__________________
Lance Hayworth 1996 Impala SS-Black, Proforged 1" lowered Auto X rear springs & Rustic Racing #750 frt., QA1 shocks all the way around, Hotckis sway bars, UMI Upper ext. control arms and BMR lowers, Poly body bushings, Dick Miller brace, 52 mm T.B., Promag 1.6 roller rockers, K&N Fipk, Quad 1 Headers and 3" pipes w/ Spintech's, Delteq 4 coil pack, MSD Opti, PCMPerformance tune, HID 50 watt frt. lights, Suncoast hood, ISSCA & GOFASST member 1955 Chevy Belair Sedan(being worked on) |
#7
In June, I had the same symptom, shutting off with no stumble. Troubleshooting led me to the ICM, but I also replaced the coil at the same time. If I remember what I read on here at the time, a bad coil can fry a new ICM fairly quickly.
__________________
#8
Ignition coil or MAF.
I know that there are those on here that say that your car will run with the MAF disconnected, but mine won't - and wouldn't do so even with the stock engine and ECU in perfect running condition. I think it is an issue specific to the 96 engine/ECU. I JUST had this same issue last week and posted a thread about it. Replaced the coil and MAF and I was back on the road. I see that you've replaced the coil recently, so change out your MAF and see what happens
__________________
![]() 1996 Caprice, a work in progress.. |
#9
__________________
#10
VF1000R, let me know if the MAF clears it up. I have another two used stock ones around my shop somewhere, and a 3" when I am ready for it. I have the 4 coil Northstar setup and have already switched them around twice so I know it should not be them. I will try the ICM also. Thanks for the input. - Lance
__________________
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
