Engine cuts out in WOT. - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > PCM Programming/Engine Management
Thread Tools Display Modes
  #1
Old 10-19-2012, 03:49 PM
LayloBrown's Avatar
LayloBrown LayloBrown is offline
LayloBrown is on a distinguished road
Default Engine cuts out in WOT.
I built a new motor for my 96 SS. LT4 top end with a hot cam and some other odd and ends. I had PCMforless do the tune. The car runs and drives fine until you give it the hammer, then it will cut out after an short climb in WOT. It happens from a dead stop, highway, and around town, but it will not happen twice in a row. I either have to restart the car or drive for an extended period of time before it cuts out again. When the engine cuts out the "Low oil level" sensor light comes on. I replaced the sensor with no change. I cut the wires to the sensor and connected them to delete it. The light is still tripped when i go into WOT. So long story short the Oil Level Sensor doesn't seem to be the issue. Does anyone have an idea as to what might be the problem here?
__________________
96 bbb
I should change my name to IBUYPARTS
Old 10-19-2012, 04:35 PM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
After verifying proper fuel pressure at WOT. Next,I would suspect the "tune". Swap in a known good PCM,and see.
  #3
Old 10-19-2012, 05:29 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is on a distinguished road
Default
I have had the high resolution opti circuit cause a cutout before but it usually sets a code. Do you have any issue restarting?
Chris
__________________
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
  #4
Old 10-19-2012, 10:46 PM
Dan Fahey's Avatar
Dan Fahey Dan Fahey is offline
Dan Fahey is an unknown quantity at this point
Default
DO the Cheap things FIRST.
New Coil WIre, Opti Cable and EGR disconnect
  #5
Old 10-19-2012, 10:56 PM
ProTools4's Avatar
ProTools4 ProTools4 is offline
ProTools4 is an unknown quantity at this point
Send a message via AIM to ProTools4
Default
1996 b-body specific!
-put razor knife in hand
-cut electrical tape off of harness from ICM / coil back to the #1 injector
-inspect the path of Pink wire from coil / ICM to the junction / splice in harness
*pink wire shoulld stay pink and be plyable
*if it is crunchy, discolored or stiff you found a smoking gun!
I have found this issue on many 1996s that under perform and or cut out.
I have seen sections of this wire completely brown & black and very burnt!
__________________
NotoriouSS Tad
96' ImpalaSS - Johhny 5 - 7.9 @ 89.07 1.734 - sshhhhh......
96' 9C1 - POS / surf sedan / Beater - traps 103MPH / 29MPG freeway~
67' El Camino - Rosie - 7.9 @ 86.5 1.77 60' on a street tire NA
15' Cruze 2.0L TD MPG machine
  #6
Old 10-20-2012, 11:28 AM
LayloBrown's Avatar
Default
Ok. I'll check the fuel pressure after acquiring the proper tools.
No issue restarting. No high res issue.
opti, cap, coil, plugs, wires, and vent harness are all new. no egr
"pink wire" issue will be looked into as well.
thx for the replies. I will keep the thread updated as I go.
__________________
96 bbb
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
