#1
My 96 DCM SS has 279,870 miles and has never had any major ENGINE work....
Still Runs Extremely Strong. What HAS Been Changed: Water Pumps - 4 - Happily under "Mr. Goodwrench" Warranty (Also Mr. "G" on my A/C Compressor !!!) OptiSpark - 1 - Changed @ 200,000 Miles "Just Because it was time" (Used OEM Replacement) Plugs and Wires - 2 - Once @ 100,000 Miles and Once @ 200,00 Miles "Because it was time" EGR - Once @ ?????? Miles "Because it failed" Idler Pulley (Belt Tensioner) - More than I can count ~ Maybe 6 ??? Exhaust Manifold Bolts - ALL - Done with heads on, Welding Nuts to Remove Broken Bolts Harmonic Balancer - Once @ ~ 150,000 Miles - Outer part was "slipping" Last edited by pjslover; 10-30-2012 at 03:39 AM. Reason: Corrected "Idler Pulley to Belt Tensioner" - ADDED ENGINE to "any major work line" |
| Sponsored Links | ||
Advertisement | ||
#2
You have to put on another 100k to get close to me. 94 Fleetwood: original manifold bolts, alternator, power steering pump, 1 water pump, original opti changed @ 250k, & still running.
__________________
![]() MR.MISK OF ISSCA-2012 95 SS Blk w/77k-FOR SALE |
#3
Impressive....I can only hope, mine is just broken in at 120K.
__________________
"A true lady takes off her dignity with her clothes and does her whorish best. At other times she can be as modest and dignified as her persona requires." \'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows. |
#4
pics...or your lying.
__________________
96 BBB borla, k&n fipk, hotchkis arms/sways, bilsteins, tri-ys, 1.6 rr/ls6 springs, 373s 98 Lumina 9c3, beater 96 BBB k&n fipk, flowmasters for sale ISSCA #2461 |
#5
221k on my gold wagon.
__________________
1995 Gold Caprice Wagon 1991 White Caprice Wagon 1991 Olds Custom Cruiser Wagon Sold 1995 RMW under construction 2004 Impala SS 2012 Chevy Terrain SL2 1974 BD-5T WIP |
#6
the last time the cluster lit up it showed 225,000 on my caprice, I don't know how accurate it is though, I also don't know what all has been changed. I noticed that the water pump looks new and all the front end components look new, tie rod ends, idler arm, ball joints etc.. and when I got the car it had a burnt up 4l60e trans.
__________________
1995 Caprice 9C1, LT1, T56 ![]() ![]() |
#7
What pics would prove my assertion? And why would i lie, what would be the point?????
#8
Check with Mike Lukens down in SoFaSSt . . . He is pushing 350,000 if he hasn't already passed it.
__________________
Howard Rothstein 1996 Impala SS Signature Series ISSCA Member 00147 (Founding Director) NAISSO Life Member 1907 DeepSouthSS Atlanta INC |
#9
308,000. I have replaced, ball joints, transmission at 220,000, 2 water pumps, 1 steering pump, MSD Cap and rotor, radiator, heater core, 160 Stat with pcmperformance.com tune, Dynomax Ultraflo SS Catback, LT4KM, K & N box filter, Delco wires and plugs, both fan motors, A/C clutch. Otherwise, usual maintenance like brake pads, oil and filter changes(Mobil 1 0w-40) and chassis lube.
Engine still runs very strong and sounds great, still doing daily driver duty. Most of the time, if I pull out of the driveway I am going to drive 60 or more miles. I think being driven on the highway a lot in a rust free environment helps with longevity.
__________________
Jim B. ![]() '95 9c1, pcmperformance.com 93 tune, Dynomax Ultraflo catback, K & N box filter, LT4 KM, 160 stat, 3.08 Posi. Last edited by fbi9c1; 10-30-2012 at 01:36 AM. |
#10
OP, I cannot believe you still have the original belt tensioner!
What happened to EGR valve? My original EGR valve had bad diaphragm but never set a code. The replacement valve has fine diaphragm but sets 32 code occasionally. Go figure.
__________________
1995 Cadillac Fleetwood Brougham 101,XXX miles. 1991 Cadillac Seville 175.000 Sold |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
