Drain Plug and Headlight Problems.... - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 11-20-2012, 12:06 AM
Gmpar Gmpar is offline
Junior Member
Gmpar is on a distinguished road
Default Drain Plug and Headlight Problems....
So the other day, I went to go change my oil as it has been WAY too long since It has been done. Upon inspection, the head of my drain plug appeared to be stripped. It used a 9/16ths socket...however, all the replacement plugs I could find are half inch...will these fit without leaking?
The other bit I have is this...before I bought my Caprice Classic it was backed into by someone in a Subaru (the one with the tire on the tailgate). This dented the hood and somehow destroyed the assembly that holds in the headlight...does anyone know where I might be able to find this part and how much it would cost?
thanks,
Gmpar
Old 11-20-2012, 12:10 AM
4x4high 4x4high is online now
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
The drain plug doesn't matter what size socket fits to remove it only that it is the proper thread for the oil pan. To answer your question, Yes it will seal assuming you have a sealing washer under the head of the drain plug before installing it. I persoanlly like the sealing washers that are metal with the internal rubber as they seam to last alot longer than the plastic or copper sealing washers.
  #3
Old 11-20-2012, 12:18 AM
Junior Member
Default
Oh, ok...yeah It's got a rubber piece on it...hope it works...
  #4
Old 11-20-2012, 01:20 AM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
original drain plugs are metric thread and 15mm wrench size iirc
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #5
Old 11-20-2012, 05:59 AM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
Best bet on the headlight assembly is a salvage unit. Go to the for sale section here, or your local salvage yard.
__________________
2005 Pontiac GTO
  #6
Old 11-21-2012, 01:56 AM
fernando fernando is offline
Junior Member
fernando is on a distinguished road
Default
Re headlights, what assembly is broken, the plastic one or the steel one where headlights and radiator are assembled? If plastic one suppose you should either buy new headlight, either go to jankyard and buy a headlight (not sure if they will sell you assebly separately fm headlight).
  #7
Old 11-21-2012, 05:37 AM
The Fooser Guy's Avatar
The Fooser Guy The Fooser Guy is offline
The Fooser Guy is an unknown quantity at this point
Default
Wow. For a minute I thought you drained all the OEM blinker fluid out of your headlights!
That stuff is almost IMPOSSIBLE to find. A few years back Kale Auto had some:
http://kalecoauto.com/index.php?main...products_id=22
__________________
The Fooser Guy
"Diagonally parked in a parallel universe."
Originally Posted by thebigbadWOLF View Post
Tested a coil by listening to MR.WOODS... ****ing coil WORKS just fine.... ass hole
  #8
Old 11-24-2012, 08:00 PM
larryfs larryfs is online now
larryfs is on a distinguished road
Default
The dealer says there are 2 possible drain plugs.
metric and SAE .
So I ordered both.
  #9
Old 11-27-2012, 11:30 AM
Turbo301 Turbo301 is offline
Turbo301 is on a distinguished road
Default
Replace the drain plug with a Fumoto oil drain valve (F107, or F107N): they make oil changes a breeze (filter notwithstanding LOL) and are a very good quality product.
__________________
1996 Caprice Classic: LT1, B4U, all options but leather; DCM/ruby cloth; stock except for hood ornament and side trim removed
2009 Pontiac G8 GT: maverick silver/onyx cloth; mods: Solo Mach catback + resonators + HFCs, AEM short ram, Livernois ECM/TCM tunes
  #10
Old 11-27-2012, 01:03 PM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
I had one of the Fumoto drain valves years ago,and they're pretty slick. Especially if the threads in the pan are "going away". Because, one can install the valve with JBweld if necessary.
Forum Jump
(c) 2007-2011 Impala SS Forum
