Steering Wheel locks and Engine shut off - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 11-21-2012, 12:27 AM
killacity17 killacity17 is offline
Junior Member
killacity17 is on a distinguished road
Default Steering Wheel locks and Engine shut off
Hey,
I'm having a problem with my 95 Impala SS 5.7 L. I was driving 2 days ago and out of no where my car starts lowering speed, steering wheel locks up to where i can't turn not even a little, the check gauge light comes on and then the low oil light comes on and the car wouldn't move. So i turned the car off then back on and it started and went back to normal after driving it a bit more it happened again, turned it off then on again and it ran then again it happened. I checked the oil and it was full ...
This happened once and found out my belt ripped up causing the steering wheel to lock up and not run.
I took it to a mechanic and they tried reading codes and nothing showed up there was NO check engine light. Does anyone have an idea of what might be the problem?
Old 11-21-2012, 12:38 AM
Gregg-O's Avatar
Gregg-O Gregg-O is offline
Gregg-O is an unknown quantity at this point
Default
Have them check fuel pressure.
"lowering speed, steering wheel locks up to where i can't turn not even a little, the check gauge light comes on and then the low oil light comes on and the car wouldn't move."
All indication that the engine has died, or is running at such a low rpm that nothing is working as it should. Fuel pump will not set a code.
__________________
Taxes are not levied for the benefit of the taxed.
\'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows.
  #3
Old 11-21-2012, 12:41 AM
Junior Member
Default
is it normal for the steering wheel to lock up though? i know better than to go to autozone and ask but i tried anyways and they were all surprised and shocked that the steering wheel locked up like they never heard it before..
  #4
Old 11-21-2012, 12:44 AM
4x4high's Avatar
4x4high 4x4high is offline
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
I'll bet the steering wheel did not lock up as you say but was VERY HARD to turn because the engine died and you no longer had power assisted steering. You could have an ICM going bad and i'm pretty sure that wont throw a code.
  #5
Old 11-21-2012, 12:49 AM
Junior Member
Default
Ok... well it seemed like it locked could be hard to turn but didn't want to try and force it. No need to get any further problems..
I'm no mechanic or big expert on cars... but when you mean "engine died" is that implying that it's going bad completely like it won't work.. or "engine died" as it shut off because there's something preventing it from running...
Thanks for the Replies by the way
  #6
Old 11-21-2012, 12:59 AM
4x4high's Avatar
Default
We mean that the engine died because something is going bad that either controls fuel or spark. The first suggestion was for a fuel issue and my suggestion is for the ICM (Ignition Control Module). The ICM is bolted to the front of the driverside head just above the ignition coil. Lots of times when they go bad the engine will restart immediately but as time goes on it usually takes a while for the ICM to cool down then the engine will start again.
  #7
Old 11-21-2012, 01:03 AM
Junior Member
Default
All right i'll look into those things see what may be the cause... thanks for the suggestions...
  #8
Old 11-21-2012, 07:18 AM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
As you will quickly learn, most AZ employees don't know sh!t about cars.
As others have said, when your engine dies, you loose the power assist for the steering. It didn't lock up, but will take full effort on your part to steer.
__________________
2005 Pontiac GTO
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
