Power Steering Pump -- STAFTED - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 11-24-2012, 12:08 PM
larryfs larryfs is offline
larryfs is on a distinguished road
Default Power Steering Pump -- SHAFTED
Not your typical failure, the pump shaft failed, and the pulley / shaft assembly started walking out. Only 1/2 the belt is remaining on the pulley. because the pulley is way out of normal position.
It's from autozone, 2005. Never abused. it's a street driven car.
Does anyone make a blue printed pump ?
I'm willing to pay for a quality pump, cause I know the return hose is non-existant.
Old 11-24-2012, 08:07 PM
NO DUBS's Avatar
NO DUBS NO DUBS is offline
Vendor
NO DUBS is on a distinguished road
Default
Dont remember what manufacturer make our pump but i do know autozone usually gives you a duralast POS. Please people dont buy from autozone, you get what you pay for.
__________________
Gotta Love The Ignorance of people...
Insanity: Doing the same thing over and over expecting different results...
  #3
Old 11-24-2012, 08:22 PM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
Default Power Steering Pump -- STAFTED
Anyone else see a connection between the people who put crappy parts on their cars,and those people with car problems.
  #4
Old 11-24-2012, 08:28 PM
Synaptic's Avatar
Synaptic Synaptic is offline
Super Moderator
Synaptic has a little shameless behaviour in the past
Default
ive seen this failure on other gm models. It isnt an uncommon faiure, even in a factory pump.
__________________
Longroof
  #5
Old 11-24-2012, 08:36 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
our pump is no longer made so anything out there will be rebuilt.
theres two major rebuilders that supply the auto chains, afaik delco does it inhouse or from a different source as they claim theirs is tested thoroughly before being shipped.
sooo, I would go with an ac delco or if you gots the time and money theres the performance rebuilders like Lee.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #6
Old 11-25-2012, 03:08 AM
Default
Anyone see a connection between trolls, and people who make stupid statements ???
the OEM pump lasted 8 years, the auto zone pump lasted 7 years. So I guess that's your defination of crappy parts. If you're going to say something, at least make it a constructive statement.
  #7
Old 11-25-2012, 04:10 AM
4x4high 4x4high is offline
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
Check out PSC for a quality pump. http://www.pscmotorsports.com/
  #8
Old 11-25-2012, 09:12 AM
1slow96's Avatar
I've experienced more trouble with parts supplied by AutoZone,than all the others combined. I don't recall any lasting over a year. Buyer beware.
  #9
Old 11-25-2012, 09:45 AM
4DoorSS's Avatar
4DoorSS 4DoorSS is online now
4DoorSS is an unknown quantity at this point
Default
Agreed, there are really only a few manufacturers that rebuild and just are relabeled for many resellers.
With that said, I would try to stick with a AC Delco part for something a little more difficult to replace, like a power steering pump or a water pump. However, as problematic some replacement parts from AutoZone some parts may be. I have no problem using an AZ part depending on ease of replacement of said part. Their warranty, price and availability make them tough to beat. Yes, I have AZ parts on my car and don't wrench on those parts anymore than other items.
When you replace your pump, be careful with the feed hose going from the reservoir to the back of the pump. It is currently not available, but it does look like Gates is going to have a replacement for us real soon.
http://www.impalassforum.com/vBullet...d.php?t=271504
__________________
  #10
Old 11-25-2012, 03:55 PM
Default
The last time I did this 7 years ago, I was stuck, so I used 5/8" heater hose. That lasted for 2 months until it was oozing oil, and leaking right through the hose. Then I got the real GM hose, probbaly the last of them at that time.
I am sure there is hydrolic oil rated 5/8" hose available. Sure having the curves would be nice, but that AN stuff will work in a pinch.
Forum Jump
(c) 2007-2011 Impala SS Forum
