L99 cylinder volume - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > PCM Programming/Engine Management
Thread Tools Display Modes
  #1
Old 11-24-2012, 03:54 PM
bigblock671 bigblock671 is offline
bigblock671
Send a message via AIM to bigblock671
Default L99 cylinder volume
Does anyone know the cyl volume on a L99?
__________________
350 musi alum heads 503 cam 11.93 1.62 60@112 n/a 11.50 @115 1.52 60 100 shot
Old 11-24-2012, 05:32 PM
4x4high 4x4high is offline
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
It is 538.92 cc's
The mathematical equation is bore (3.736) x bore (3.736) x stroke (3.00) x 12.8704 = swept volume of 1 cylinder
  #3
Old 11-24-2012, 11:23 PM
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka is an unknown quantity at this point
Default
Originally Posted by 4x4high View Post
.......The mathematical equation is bore (3.736) x bore (3.736) x stroke (3.00) x 12.8704 = swept volume of 1 cylinder
........hell, I'd just do 4.3 divided by 8 = .......
That would get you into the neighborhood .
KW
__________________
1996 BBB SS, 398ci SR
1995 DCM SS, 355ci
  #4
Old 11-24-2012, 11:48 PM
Default
KW
Well assuming you mean divide 4.3 liters by 8 that would only give you the liters for one cylinder NOT the CC's of swept volume. Now assuming you mean to divide the 262 cubic inches that would only give you the cubic inches for 1 cylinder and still not the CC's of swept volume.
I'm assuming the OP is trying to figure out either his existing compression ratio or needs the info to change the compression ratio by using heads with a different combustion chamber volume or pistons to achieve a different compression ratio.
  #5
Old 11-25-2012, 12:15 AM
91ss's Avatar
91ss 91ss is offline
91ss is on a distinguished road
Default
Or maybe he is looking for the right value to put into his bin file since he's in the PCM section?
  #6
Old 11-25-2012, 01:06 PM
Marky Dissod Marky Dissod is offline
Marky Dissod is an unknown quantity at this point
Default
GM's answer for this value is
537.94
__________________
OPTION-LESS 94 Chevy Caprice Classic Wagon … GU6 & G80
PCM Performance … NO OIL COOLER, JUST 0W40 … TB-IAT-MAF-Filter-Inline intake + heatshield … Monroe Severe Service 550012 & 550013 Shocks … BMR 1.26" Solid Front Swaybar … WP118HD …
MAF Sensor DISabled, Speed Density Calibrations in progress … 160°F Summer tune or 180°F Winter tune
  #7
Old 11-28-2012, 04:50 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is an unknown quantity at this point
Default
Wonder what he's up to? Didn't get to see him at all this year. Maybe putting a blower on it? Awwrighty Keith, whatcha doin?
Chris
__________________
Originally Posted by Erik View Post
My first advice to you is to edit that and call me from a payphone.
Originally Posted by Goldmaster View Post
I really can't say for sure. Once the roofies kicked in she seemed calm and easy going.
  #8
Old 11-28-2012, 07:15 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
Volume of any cylinder is: Height*pi*(diameter^2)/4.
__________________
2005 Pontiac GTO
Forum Jump
(c) 2007-2011 Impala SS Forum
