factory security in 9c1? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91 thru 96 B-body Model Specific > Caprice
Thread Tools Display Modes
  #1
Old 11-28-2012, 01:02 PM
Philly9c1 Philly9c1 is offline
Junior Member
Philly9c1 is on a distinguished road
Default factory security in 9c1?
Got a 95 9c1, th8s shop is tryn to tell me there a factory security system on my car. I'm pretty sure he's blowin smoke.
Old 11-28-2012, 01:08 PM
4DoorSS's Avatar
4DoorSS 4DoorSS is offline
4DoorSS is an unknown quantity at this point
Default
He's probably referring to the VATS system.
__________________
  #3
Old 11-28-2012, 01:19 PM
Junior Member
Default
Would that allow the car to star then cit it off cut tho. And would u have to find codes to clear it
  #4
Old 11-28-2012, 03:19 PM
Hamilton Chevrolet's Avatar
Hamilton Chevrolet Hamilton Chevrolet is offline
Hamilton Chevrolet is on a distinguished road
Default
9C1's do not have the vats system so that every officer could get in any car and have them all keyed the same for their department. There was no vats in the cruisers that I have ever seen.
Mike--Hamilton Chevy
  #5
Old 11-28-2012, 03:40 PM
Junior Member
Default
So he's blowin smoke basically. And it s an NYPD car
  #6
Old 11-28-2012, 04:52 PM
fbi9c1 fbi9c1 is offline
fbi9c1 is an unknown quantity at this point
Default
As Mike stated, no VATs systems in 9c1's.
__________________
Jim B.
'95 9c1, pcmperformance.com 93 tune, Dynomax Ultraflo catback, K & N box filter, LT4 KM, 160 stat, 3.08 Posi.
  #7
Old 11-28-2012, 07:21 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
To be absolutely correct, there IS a VATS system in '94-'96 (and maybe earlier) 9C1's, but it is disabled. There is a white wire under the dash that takes the place of the resistor circuit through the key. With this, the VATS module always sees full reference signal voltage, so the car will always start and run. Also, 9C1 VATS modules never 'learn' a resistance value because of this. In my old '95 9C1, I tapped into this white wire and added a hidden toggle switch under the dash. Switch on, all is well. Switch off, and the car will not stay running on the next startup.
__________________
2005 Pontiac GTO
  #8
Old 11-28-2012, 08:19 PM
95wagon's Avatar
95wagon 95wagon is offline
95wagon is an unknown quantity at this point
Default
To be really accurate, it's half there
The theft deterrent relay is not there on the 9C1
The start wire goes directly from switch to starter.
The VATs module's sole purpose is to "tell" the PCM it can run the injectors.
Cletus , you say the VATs module never learns a resistance value.
So are you saying it is still "green " and could?
I was under the impression , and possibly wrongly, that the 9C1 module had learned that no resistance is required
Gerry
__________________
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
Drag strip pics and video
My Wagon
My W-31 Cutlass
  #9
Old 11-29-2012, 11:07 AM
Junior Member
Default
So u just ran a two prong switch on the wire? U got a pics
  #10
Old 11-29-2012, 04:48 PM
Junior Member
Default
[Is this it on the drivers side over the ebrake attached to a green connector
Forum Jump
(c) 2007-2011 Impala SS Forum
