Interior Lights - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 11-28-2012, 06:15 PM
fat boys ss fat boys ss is offline
fat boys ss is on a distinguished road
Default Interior Lights
Hi all!
My interior lights are not working properly. When I open the doors only the light under the dash and the lights on the door come on. The dome light, the two lights in the rear view mirror and the two rear lights on the coat hooks do not come on. But when I close the door, and the lights that ARE on, shut off then I can manually put the lights on on the rear view and the coat hooks. Can anyone help me in solving this problem? I checked for grounds, they look good. Car is a 94 B4U Caprice. Any help would be much appreciated.
Old 11-28-2012, 06:27 PM
4DoorSS's Avatar
4DoorSS 4DoorSS is offline
4DoorSS is an unknown quantity at this point
Default
Did you check your fuses?
Is your vanity mirror out too? If so,there is a harness that supplies power to items you mentioned. Iirc this harness, runs up the driver side B Pillar. Pull the 2 pillar covers off and check for voltage there, damage to the harness, etc.
__________________
  #3
Old 11-28-2012, 07:56 PM
SSTUNNER96 SSTUNNER96 is offline
SSTUNNER96
Default
I have the same exact problem and can not find the cause. when I shift the car in when I shift the car in reverse the lights go ou pleasplease help
__________________
JOE
1996 BBB
  #4
Old 11-28-2012, 08:24 PM
Default
thanks a lot will look at the fuses
  #5
Old 11-28-2012, 11:15 PM
SSTUNNER96
Default
I've been researching some old posts and I will be checking the green box(chimes) and interior relay under the drivers side dashboard just above the brake pedal.
__________________
JOE
1996 BBB
  #6
Old 11-29-2012, 09:42 AM
Zebrafive Zebrafive is offline
Zebrafive
Default
Originally Posted by fat boys ss View Post
Hi all!
Since your door and dash lights work the interior lamp relay is OK.
Since you can manually turn on the mirror and rear lights they have power and the fuses are OK.
Some place from the lights not working and the interior lamp relay there is a break/bad connection in the dark blue/white wire. Since all the lights you mentioned are not working the break/bad connection must be after they splice into one wire. I would check starting where that wire goes down the B pillar to the relay.
__________________
96 DCM 1st Mod. 12way Bonneville seats, MOMO shift knob,Gentex Homelink comp/temp mirror,more to come!
  #7
Old 11-29-2012, 11:15 PM
SSTUNNER96
Default
I found the problem on my 96 impala, I had a bad harness on the right side rear under the carpet inside the stock black wire loom that runs along the floor. I rewired and walah! everything works correctly now and i believe it was the blue/white wire that had a bad connection.
__________________
JOE
1996 BBB
  #8
Old 12-01-2012, 07:41 PM
Default
Got it it was the blue/white wire the had the break in it by the connecto right at the the bottom of the B pillar .the connecto was all f**ked up so i cut it out and soldered the wires together and it worked lol
thank you all for the help happy holidays
Forum Jump
(c) 2007-2011 Impala SS Forum
