Throttle body bypass QUESTION - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 12-02-2012, 08:33 PM
BIGBODY 94's Avatar
BIGBODY 94 BIGBODY 94 is offline
BIGBODY 94 is on a distinguished road
Default Throttle body bypass QUESTION
I live in ga is it necessary to do a Throttle body bypass , i heard it keeps the TB from iceing up in the winter,it dont get as cold here as up north,thoughts?? thanks
Old 12-02-2012, 08:36 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
do eet.
Ive never heard of anybody icing up their tb.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #3
Old 12-02-2012, 08:46 PM
BIGBODY 94's Avatar
Default
so still do it? its there a proper way to do it to a 96
  #4
Old 12-02-2012, 09:32 PM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
Absolutely,do it. They're all the same. After draining some coolant,remove the elbow from the steam pipe to the throttle body. Disconnect the line to the throttle body from the coolant reservoir,at the throttle body. Connect the line to the steam pipe,after trimming for length. It''s that easy.
  #5
Old 12-02-2012, 10:10 PM
coltonx3 coltonx3 is offline
coltonx3 is on a distinguished road
Default
i did mine on my 95 9c1 yesterday u dont have to cut the line from the reservoir just push the line on the steam pipe all the way ill put a pic in a lil
  #6
Old 12-02-2012, 10:33 PM
Tim M. Killmeyer's Avatar
Tim M. Killmeyer Tim M. Killmeyer is offline
Tim M. Killmeyer
Default
You got it backwards... the throttle body set up as it is (stock) keeps it from freezing up. You will never have a chance for it to freeze in GA so, yes, DO IT!
I live in Pittsburgh and never worried about it and as someone else said... I've never heard of someone icing up their tb.
Tim
__________________
Tim Killmeyer
Pittsburgh, PA
'95 BBB Impala SS
'06 Scion xB
'01 BMW K1200RS with ARMEC sidecar
'01 Suzuki 1200 black, naked Bandit
'06 Honda Big Ruckus
  #7
Old 12-02-2012, 10:39 PM
BIGBODY 94's Avatar
Default
i need a easy diagram to do this
  #8
Old 12-02-2012, 10:40 PM
BIGBODY 94's Avatar
Default
please do and @ tim ok will do
  #9
Old 12-02-2012, 10:58 PM
BigB9000 BigB9000 is offline
BigB9000 is an unknown quantity at this point
Send a message via ICQ to BigB9000 Send a message via AIM to BigB9000
Default
Tim
If anything, bypassing the TB will PREVENT the TB from icing up.
(removing the coolant from it, hints, no liquid to freeze)
Pretty sure it was just for emissions (warm the air up, blah blah blah)
__________________
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
  #10
Old 12-02-2012, 11:59 PM
xxxmalosoxxx xxxmalosoxxx is offline
Junior Member
xxxmalosoxxx is on a distinguished road
Default
You should definitely do the TB bypass. I did it to my 95 Z28, 96 Impala and 04 Denali XL. Never had any problems and the temp dips into the mid 30's during the winter.
Someone on this forum posted a nice diagram on how to do the TB Bypass. Here's the link: http://www.impalassforum.com/vBullet...d.php?t=256697
I think the hp gain is 5-6hp average. Here is a link to a dyno before/after comparison chart from a 96 'Bird. http://www.ws6.com/mod-8.htm
Forum Jump
(c) 2007-2011 Impala SS Forum
