Bad bearing, power steering pump, alternator??? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 12-22-2012, 02:54 AM
SSHAMU94 SSHAMU94 is offline
Junior Member
SSHAMU94 is on a distinguished road
Default Bad bearing, power steering pump, alternator???
Hey guys. Recently I've noticed a sound coming from the drive belt. At first I thought my belt was going bad, but it wasn't that ( it was changed two months ago). Then I thought it was the tensioner pulley...so I replaced it with a new one...still had that noise (FYI, the noise sounds exactly like a loose belt). The ac/compressor is brand new...it's not that. So I'm pretty much down to the alternator or the power steering pump. My feeling is that it's not the alternator, but I will have it checked out. My question is this...if it is a bad PS pump...wouldn't I notice it while driving (ie: turning/steering the car)??? Could it be a bearing inside the pump? Any thoughts about how much it would be to have it rebuilt?
Also, while removing the alternator, I snapped off the plastic clasp on the wire that connects to it! As I'm sure most of you have experienced this...it's quite annoying. The plastic is so brittle. I ordered a new wire/clasp from rock auto however...where does this wire lead to? I tried following it along the fuel rail but stopped as it became more cumbersome when it started to merge with larger and larger bundles of wire. When I get the new wire, should I just splice the old wire and connect the new wire/electrical connector to it???
Please...Anyone...HELP ME!!!
Thanks,
Mike
Sent from my iPhone using AutoGuide.com App
Old 12-22-2012, 08:08 AM
4x4high 4x4high is offline
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
I would lay odds on the bearing noise coming from the alternator. The new wire/connector I would suggest you remove the wire(s) from the connector and only change the connector and leave your wire(s) uncut and original.
  #3
Old 12-22-2012, 08:58 AM
turbochris turbochris is offline
turbochris is an unknown quantity at this point
Default
take the belt off and start it and see if it makes noise. if it does it's not the alt or ps pump because they're not spinning.
Some connectors the contacts cant push out the back may have to change the whole connector.
__________________
95 RM wagon
96 Caprice B4U
94 Caprice B4U
2000 Dodge Caravan http://www.youtube.com/watch?v=Rdi8EkTGztY
  #4
Old 12-22-2012, 09:12 AM
Default
ALL connectors can be removed from the wiring, you just need the proper removal tool to do so.
  #5
Old 12-22-2012, 09:32 AM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
Any quality starter/alternator rebuilding service has those pig-tails. They're common as dirt,and relatively inexpensive. Support your local businesses while they still exist.
  #6
Old 12-22-2012, 09:54 AM
Default
There's some connectors that you have to put the wire through first, crimp, then pull the contact into the housing by pulling the wire. Cant remember which one.
__________________
95 RM wagon
96 Caprice B4U
94 Caprice B4U
  #7
Old 12-22-2012, 12:21 PM
95wagon's Avatar
95wagon 95wagon is offline
95wagon is an unknown quantity at this point
Default
Pull to seat
Normally has a "." in the series
Like,
a normal metripac 1.5 mm terminal is 150 series
http://www.eficonnection.com/eficonn...spx?ItemId=216
a pull to seat 1.5 mm terminal is 150.2 series
http://www.eficonnection.com/eficonn...spx?ItemId=214
The normal terminal has no seal for inside use and a crimed on seal for outside with retainer.
One individual seal per wire and then the secondary lock http://www.eficonnection.com/eficonn...spx?ItemId=302
The pull to seat has a seal visible in the rear that all the wires go through
http://www.eficonnection.com/eficonn...spx?ItemId=208
__________________
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
Drag strip pics and video
My Wagon
My W-31 Cutlass
  #8
Old 12-22-2012, 12:57 PM
Junior Member
Default
Thanks, to all of you! I love this forum! It's amazing how you guys take the time to help others! It really is like another family on here. Merry Christmas to you all and happy new year! I'll update u guys and let you know how I made out. Thanks again
  #9
Old 12-22-2012, 11:58 PM
BigB9000 BigB9000 is offline
BigB9000 is an unknown quantity at this point
Send a message via ICQ to BigB9000 Send a message via AIM to BigB9000
Default
I second just swapping the alternator connector body.
Its not a pull to seat, so you dont have to worry about that.
__________________
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
  #10
Old 01-06-2013, 09:23 AM
Junior Member
Default
Update.
I found the wire connectors I needed from PEP BOYS! I ordered the new housing (plastic connector for the alt) from rock auto. So this problem is solved.
NOW...as for this noise...I pulled the power steering pump out. I would like to get it tested before I have it rebuilt or replaced. Does anyone know where I can take this to be tested? I live in Long Island, NY. If it is a bad pump...should i have it rebuilt or order a remanufactured one off of rock auto?
I really hope this noise goes away after I put everything back together. The funny thing is...I never had a problem that would indicate it was the Power Steering Pump. It didn't struggle to turn...never made those typical noises that would lead you to believe it was the pump. BUT its the only thing left on the drive belt that hasn't been replaced with a new part. And the noise sounded like it was coming from that area (noise sounds exactly like a loose belt). BTW...I had the alt tested...it was fine. AC/Clutch Compressor...brand new and noise is NOT coming from it. The tensioner pulley is brand new (I thought it was this at first because i had a new belt and it made that "loose belt noise")
Please let me know if anyone has any suggestions.
thanks again guys.
Forum Jump
(c) 2007-2011 Impala SS Forum
