Can't reset 'change oil' light??? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 12-24-2012, 04:13 PM
Chicagoareabmx's Avatar
Chicagoareabmx Chicagoareabmx is offline
Chicagoareabmx
Send a message via AIM to Chicagoareabmx
Default Can't reset 'change oil' light???
Please don't poke too much fun!
My 'Change Oil' light on the dash hasn't come on since I swapped in the T56 back in April, after putting probably 7k on the odometer and 3 oil changes. I'm not sure if it has a programmed mileage interval, or what that might be, but I figured it had been so long that the bulb had just burnt out or something. Battery has also been disconnected a few times in that period.
Just the other day the light came on while driving from Bethlehem PA to Chicago IL, and I can't get it to reset with the gas pedal method like I used to. Key on, engine off, pump the gas pedal 3 times, no reset. KOEO, pump 3 times and hold on the 3rd, no reset.
Am I doing something wrong?
The PCM is flashed with a 95 Fbody T56 tune, if that changes anything?
Does disconnecting the battery reset the light?
Happy Holidays too!
__________________
Brian
95 LT1/T56 9C1
Gettin REAL FUN!
Old 12-24-2012, 07:01 PM
CRSSDCM's Avatar
CRSSDCM CRSSDCM is offline
CRSSDCM has a little shameless behaviour in the past
Default
The oil life monitor computer algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm.
I quote:
"The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of he oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc. There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine. You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application. The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc. are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line."
Now.......
The F bodies required that you hold the trip reset button for 15 seconds while the key was in the start position.
I dont think removing the battery negative cable for any length of time will reset that light.
__________________
1 of the 12,180 since March 1996.
Denise Milani is the hottest female ever created and put on this planet. Case closed.
Originally Posted by Got 'Cupcake' Bearings? View Post
Sorry to break it to you but Metal is dead. The 80's ended a long time ago.
"I am Metal and I'll never die. We are Metal and we'll never die." -Ronald James Padovano
  #3
Old 12-25-2012, 05:24 PM
NADACOP NADACOP is offline
NADACOP is an unknown quantity at this point
Default Bad cluster?
I've got the exact same thing going on with my 92K mile 9C1. The change oil light would reset every time using the conventional method up until the last oil change this past November. It's been on ever since and won't reset. I believe it's a cluster problem since several other things also aren't working. The trip odometer only works below 40 degrees and the temp guage won't work even though the sender and wiring have been replaced.
I was going to swap in a different cluster but don't want to break any of the plastic dash parts in the cold.
Jim
__________________
Your struggle doesn’t reflect your weakness, it reflects your strength. The fact that you're still battling is an indication that you've not been beaten.
  #4
Old 12-25-2012, 05:49 PM
turbochris turbochris is offline
turbochris is an unknown quantity at this point
Default
TPS sensor bad maybe?
__________________
95 RM wagon
96 Caprice B4U
94 Caprice B4U
2000 Dodge Caravan http://www.youtube.com/watch?v=Rdi8EkTGztY
  #5
Old 12-25-2012, 09:52 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
[QUOTE=NADACOP;2722043 I believe it's a cluster problem since several other things also aren't working. The trip odometer only works below 40 degrees and the temp guage won't work even though the sender and wiring have been replaced.
Jim[/QUOTE]
Can't be the cluster. It's just a bulb in the cluster, the PCM controls the light.
+1 on checking TPS.
__________________
2005 Pontiac GTO
  #6
Old 12-26-2012, 03:34 PM
Chicagoareabmx
Default
Thanks for the replies guys.
If the TPS was that out of whack, wouldn't it cause all kinds of other fairly noticeable driveability issues?
Maybe I can check it tomorrow if it's a little warmer out, or at least sunny.
What should I be looking for and in what positions?
__________________
Brian
95 LT1/T56 9C1
Gettin REAL FUN!
Forum Jump
(c) 2007-2011 Impala SS Forum
