heat not working - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Heating/Cooling/HVAC
Thread Tools Display Modes
  #1
Old 12-28-2012, 05:28 PM
Ztater's Avatar
Ztater Ztater is offline
Ztater is on a distinguished road
Default heat not working
the heater on my car works for a few seconds and then gets cool if i turn the heater fan down for a min and then turn it back on its hot again but only for a lil bit then cool again any trouble shooting that i can do
__________________
95 caprice
Old 12-28-2012, 05:46 PM
jking1118's Avatar
jking1118 jking1118 is offline
jking1118 is on a distinguished road
Default
http://www.impalassforum.com/vBullet...=coolant+flush
__________________
Jonathan
96 Impala SS, DGGM, 2nd owner, 98k miles, #39736 of 41934, Build Date - 22 November 1996
92 Honda Accord 2 door, 338k miles, daily driver
06 Honda Accord 4 door, wife's car
02 Chevy K2500 regular cab, lwb, 6.0 gas
84 Chevy K10 regular cab, SWB, 305 w/4 speed granny, sentimental family truck
67 Camaro, body only, Pro Touring type car planned.
  #3
Old 12-29-2012, 10:09 AM
st95ss's Avatar
st95ss st95ss is offline
st95ss is an unknown quantity at this point
Default
look, listen & learn bruh, this is the best site, welcome
__________________
95 DCM Impala SS, G2 Cold Air Induction,G2 power pulley kit w/ v-belt ,G2 throttle body plate, G2 air foil,G2 Valve Cover Breather,pcmperformance tune, 160 thermostat,Borla Full Stainless Steel Exhaust, tri-y headers, 12 way Bonnie, air pump delete, 91 Caprice tailights SSittin on TIS 06's 22's
# 3,683 of 18,365
http://www.cardomain.com/ride/229728...ellville-ga-us
  #4
Old 12-29-2012, 09:13 PM
Ztater's Avatar
Default
i flushed the coolant about 10000 miles ago when i replaced my opti the coolant is still green and looks to be in great shape
__________________
95 caprice
  #5
Old 12-29-2012, 09:29 PM
Crime Scene 96's Avatar
Crime Scene 96 Crime Scene 96 is online now
Crime Scene 96 is on a distinguished road
Default
Its been well documented that coolant flushes could take several attempts.
Has your heater hose assembly been replaced? Also when the flush was done, how was it done or did a mechanic/dealer do the job for you?
__________________
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
  #6
Old 12-30-2012, 08:40 PM
MUSSCLE in Milwaukee MUSSCLE in Milwaukee is offline
Send a message via ICQ to MUSSCLE in Milwaukee
Default
Try reversing the hoses. Worked for me.
__________________
'96 SS - 12.887 at 103.06 mph with a 1.675 60-ft. Member of the "12-Second Bolt-On Club "
Yep. That is Ashley Force.
  #7
Old 01-01-2013, 03:24 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
Did you pressure flush the heater core as part of this? If not, it's still full of crud.
__________________
2005 Pontiac GTO
  #8
Old 01-01-2013, 09:36 PM
BBODYLT1's Avatar
BBODYLT1 BBODYLT1 is offline
BBODYLT1 is an unknown quantity at this point
Send a message via AIM to BBODYLT1
Default
Yeah I would definitely back flush the heater core, simply remove one of the hoses leading to the fire wall then use a garden hose on full blast to flush the crap out. I've done this on all the caprices I've owned, after that I could only use the heat on the lowest setting because it was to hot...lol
__________________
99 Regal GS
HDI cold air|Gen-V Supercharger|3.5 Pulley|N* TB|LQ4 MAF|Drilled 180 t-stat|AL104 plugs|PJR wires|Alt rewire|9c1 Trans cooler|3.29 gears|TOG headers no cat no res|GTP dual exhuast|GTP trans mount|Flipped M/M's|Monte braces|Rear strut tower bar|GMPP Front-rear sway bars|GMPP trailing arms|9c1 struts|C-5 Corvette brakes|GTP HUD|05 GTP seats|Custom tuned.
  #9
Old 01-02-2013, 01:57 PM
Dan Fahey's Avatar
Dan Fahey Dan Fahey is offline
Dan Fahey is an unknown quantity at this point
Default
YUP..I put in my 3rd Heater Core..
The first two were cheap replacements..
I bought a Delphi Heater Core this time and paid a little more.
Now I have to use th lowest setting..
Time for a new Motor and it buzzes a little \
D
__________________
  #10
Old 01-06-2013, 07:59 AM
st95ss's Avatar
Talking
last week got in the whip and turned heater on, cold was pouring out, thought I was in Alaska, it was so cold, took it to Byrons and they changed a couple of hoses and sucked some gunk out and that baby, feels like in in Hawaii, thought I would share this seeing that I drive the whip every 3 1/2 to 4 months when I get here
__________________
# 3,683 of 18,365
Forum Jump
(c) 2007-2011 Impala SS Forum
