Need Help in Tampa - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91 thru 96 B-body Model Specific > Caprice
Thread Tools Display Modes
  #1
Old 12-29-2012, 03:00 PM
SoberSport SoberSport is offline
Junior Member
SoberSport is on a distinguished road
Default Need Help in Tampa
Hello all!
My car, 1996 Impala SS, isn't running right and I just don't have the tools, room, or patience to trouble shoot the problem myself. I've done a search for "rough idle" and discovered that it could be anything from a vacuum leak to fuel delivery to exhaust to ignition. I really hope that it isn't the opti. I went through that whole process on my '96 Z28 years ago.
I was driving the other day when all of a sudden I noticed a rough idle at a stop light. As I accelerated and got between 1000 and 1500 rpms, the car would slightly surge and drop back surge drop back etc. Far from running smooth. I can't "feel" any loss of power and when I really put my foot into it the problem isn't noticeable.
I changed the fuel filter, hoping that I would get lucky. While the old fuel filter didn't flow as well as the new one, this did not fix or even improve the problem. So, I took it to a "trusted" shop. They checked the exhaust and ran seafoam through the car. Still, no improvements. They said a lot of condensation/water came out the tail pipes indicating that I may have gotten bad gas that was high in ethanol. I was told to run the gas through before filling the tank and hopefully that would solve my problem.
Now when I first start the car up for the day, when it is cold, it runs fine. Within a couple minutes, the idle gets rougher.
That's what the car is doing. What I really need is someone who is very familiar with the car and or the LT1 in the Tampa Bay area that can help me figure out and fix the problem. I'll pay you, of course. Or, is there a shop in the area that knows our cars. The shop I went to does not. Any help or guidance would be much appreciated. This is the only car I own so I need it to run right.
Thanks in advance for your help and replies!
Dave
1996 Impala SS
Old 12-29-2012, 05:07 PM
DougDePew DougDePew is offline
DougDePew is on a distinguished road
Default
Originally Posted by SoberSport View Post
Hello all!
Dave
1996 Impala SS
Quick check for vacuum leaks - get a can of carb cleaner - with car running, spray it around the vacuum hoses and manifold - RPM's will climb when you hit a leak.
I could listen to it if we could coordinate it with a day I'm in Tampa. I know I'm there on Wednesday of this coming week.
  #3
Old 12-30-2012, 08:07 PM
Junior Member
Default
Thanks Doug! I picked up some carb cleaner and will try that trick tomorrow. I would definitely take you up on your offer to take a listen when you are in the Tampa area later this week should I not find the problem before then.
Dave
  #4
Old 01-01-2013, 07:39 AM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
A cheap item to check is the PCV valve. If it is no working, they are only about $3. When they are not functioning, they cause similar problems to yous.
__________________
1991 OCC upgraded LO5, wrapped headers, dual Flowmasters, 3.23 posi, drop spindles & springs, Stainless full moons, 255/60/15 R, 215/70/15 F, Recaros, Nardi/MOMO SW w/QR, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi
For a parts list, check Plenty of good parts
Old mechanic's saying: If it doesn't work, hit it with a hammer...if it still doesn't work, use a bigger hammer...if it breaks, it needed replaced anyway.
  #5
Old 01-01-2013, 04:13 PM
Junior Member
Default
I was unsuccessful in finding a vacuum leak. However, there is one thing that I left out by mistake. In this picture you will see a cork in the end of one of the hoses coming out of the AIR pump. This hose was attached to nothing so I put a cork in it. This didn't seem to change the way the engine ran at all so I left it there. Could this be part of my problem? The hose that went to nowhere?
Click image for larger version
Name:	A.I.R. Pump Cork.jpg
  #6
Old 01-01-2013, 04:37 PM
96SSbbb's Avatar
96SSbbb 96SSbbb is offline
96SSbbb is an unknown quantity at this point
Default
That hose goes to the air box, its for the air pump.
__________________
ISSCA# 930
  #7
Old 01-01-2013, 04:46 PM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
Hose pictured (w/cork) is the air inlet to the AIR pump,and should be going to a nipple on the air-box. If that nipple is "open",that's not the way it is supposed to be. Personally,I deleted the AIR pump along with many others.These are not good cars to "throw parts at" there are just too many possibilities. O2 sensors,EGR valve can cause driveability issues also.
  #8
Old 01-01-2013, 06:22 PM
Default
Not sure where in Tampa you're at. Tomorrow morning I'll be in the Gibsonton/Brandon/Seffner area.
  #9
Old 01-01-2013, 09:51 PM
Junior Member
Default
Thanks everyone. And thanks 1slow96. I understand that throwing part at it is a shot in a dark. Thing is, I don't know anyone in Florida that knows LT1s. I'm hoping to connect with someone eventually because I simply don't have the patience, knowledge, or tools to figure this out on my own. Friends of mine have their trusted mechanics the know how to fix "anything" till they open the hood. I experienced this with my '96 back in the day years ago. Fortunately, I found a guy, but that was in the state of Washington. Now, I need a guy in Florida. Thanks again!
Dave
  #10
Old 01-01-2013, 11:08 PM
1slow96's Avatar
When I find myself out of ideas. I go to my local Chevrolet dealer,and they very seldom disappoint.
Forum Jump
(c) 2007-2011 Impala SS Forum
