Any Camaro owners in the house? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #1
Old 01-01-2013, 09:33 PM
ajharman's Avatar
ajharman ajharman is offline
ajharman is on a distinguished road
Default Any Camaro owners in the house?
I just bought a 1994 z28 camaro. Its an lt1/t56 manual and has some nice parts on it. It has no oil pressure in the motor and is making some pretty noticeable noises in the valvetrain. The price was right though. I was planning on pulling my spare motor out of my parts wagon to swap into the camaro so it will be drivable while I see how much damage the original engine has and possibly rebuild it if it isn't completely trashed.
I know the obvious difference in heads/cam/MAF, and that that won't be an issue if I reuse the MAF and PCM. But I was wondering more about the accessories, sensors, plugs, and things like that. Both motors are 94's.
How much stuff will I have to switch over to make that work? And will that be worth it, or should I focus on the camaro motor first? I think F-bodies didn't switch to vented opti's till 95, will that matter either?
I know this is not a camaro forum, but I've gotten so much good input on all kinds of LT1 stuff from you guys on here and know people have done this before. Just wanted to see what input my fellow B-Body faithfuls might have.
__________________
-1994 Roadmaster Wagon
, White, LT-1, Mild PCM Tune, Wood Delete, Home-Plate Delete, PVC Intake w/ K&N Filter, Moog 7268 and CC625 Springs, Hotchkis Sway Bars F&R, Tubular Rear Control Arms, Flowmaster 40's, SS Wheels, 160 Powerstat, All-Aluminum Radiator.
-1994 Camaro z28 - Stock LT1, t56 6-speed Manual, Intake, MSD Coil/Wires, New project, Needs some love
http://s1118.photobucket.com/albums/...aster%20Wagon/
Old 01-01-2013, 11:52 PM
KW Baraka KW Baraka is online now
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka is an unknown quantity at this point
Default
Originally Posted by ajharman View Post
I just bought a 1994 z28 camaro...........I was planning on pulling my spare motor out of my parts wagon to swap into the camaro......Both motors are 94's.......How much stuff will I have to switch over to make that work.......
Swap engine for an engine......and use ALL of your Camaro accessories except the oil pump which is probably bad.
I don't know if the F-body and the B-body use the same oil pump.....so you may have to buy a new oil pump vs using the one from the wagon.
Also, be prepared to buy/install new motor mounts.
KW
__________________
1996 BBB SS, 398ci SR
1995 DCM SS, 355ci
  #3
Old 01-10-2013, 10:03 AM
Gene Beaird Gene Beaird is offline
Gene Beaird
Default
It's been a while since I've seen this done, but you'll probably want to swap the long blocks (block and heads) and use the manifolds and accessories for the Z in the Z. IIRC, there are a couple of sensors that have different connectors that take some work to make them work if you use the B-body sensor in the F-body.
I had a couple of friends who are quite knowledgeable in GM vehicles who swapped in a b-body engine into a 94-95 f-body. They mentioned the connectors, but I don't remember what they were. They also mentioned that their Z would run rough for approximately 30 seconds after a cold start. They swapped a bunch of stuff around, and borrowed my 95 Camaro FSM for a while to try to chase circuits and troubleshoot, but never discovered what the issue was. After that, the car ran fine, it was just a PITA to start and run in front of someone looking to buy the car after they put it together. They eventually sold the car like that, and AFAIK, it's still running like that.
That issue may have been specific to that engine/car combination and have been fixed if/when they put the original engine back in the engine bay, but that was an issue they had. Since you're planning on doing so temporarily, you should have no issue with the swap, especially when you swap things back in.
I don't think you'll need a different oil pump. Just use the one that's already in the temp engine you're using.
__________________
Gene Beaird
95 DGGM SSSS, HAIL
96 BBB SSSS, HAIL 'WarPig'
95 9C1 Caprice
92 B4C 1LE Camaro
85 Firebird, SCCA CP Solo II
95 381 LT4/6SP Z28 Vert - 405 RWHP (Her Car)
Pearland, Texas
  #4
Old 01-10-2013, 10:19 AM
DougDePew DougDePew is offline
DougDePew is on a distinguished road
Default
Main one is the temp sensor in the head - it's on passenger side for B, driver's for F
Either extend it or struggle with the plug in the head. It's an uncommon size, 5/16" square male tool needed.
  #5
Old 01-10-2013, 10:27 AM
4DoorSS's Avatar
4DoorSS 4DoorSS is offline
4DoorSS is an unknown quantity at this point
Default
As you know the engines are essentially the same. One big difference is in the crankshaft hub on both. If you intend to use the same accessories from the camaro (which I would recommend in that tight engine bay) then be sure to swap over the crankshaft hub for the balancer. Also the water pump is different on both but you would probably pull this anyway to swap.
The alignment of the pulleys is differnt on the fbody, bbody and Vette due to each having its own crankshaft hub. Most other parts should be the same but fuel delivery (fuel rail) may be differnt but have not worked on many camaros of that generation. More familiar with first and second gen camaros.
__________________
  #6
Old 01-10-2013, 10:32 AM
ajharman's Avatar
Default
Originally Posted by Gene Beaird View Post
It's been a while since I've seen this done, but you'll probably want to swap the long blocks (block and heads) and use the manifolds and accessories for the Z in the Z. IIRC, there are a couple of sensors that have different connectors that take some work to make them work if you use the B-body sensor in the F-body...
Thanks for the info Gene. I'm hoping to start pulling the motor soon, so that should be good info. I'll try to swap over as many of the f-body parts as seems practical for the temporary nature of the situation.
__________________
  #7
Old 01-10-2013, 11:38 AM
94SSman 94SSman is offline
94SSman
Default
Come get the spare F-body LT1 I have.
__________________
94 Impala SS- Procharger, etc...501 RWHP
70 El Camino SS 396
72 Chevelle SS- for sale
70 Chevelle Convertible work in progress
70 Chevelle hardtop
  #8
Old 01-10-2013, 11:45 AM
ajharman's Avatar
Default
Yeah that might make the most sense afterall. Do you remember what year it is offhand? If its a 94 or 95 that would probably be the easiest route. IIRC 93 and 96+ have some differences compared to a 94.
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
