Fuel pump or regulator - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 01-16-2013, 11:36 PM
FEHLER1977 FEHLER1977 is offline
Junior Member
FEHLER1977 is on a distinguished road
Default Fuel pump or regulator
I have a pretty simple question for anyone who mouight have the answer. I have a 96 SS and I recently started noticing some bad hesitation when exceleration. I check the fuel pressure and it's reading about 35 at idle. even if I rev the engine up it barely gets to 38 or 39. Is this an fuel pump regulator issue or a fuel pump itself problem
Old 01-17-2013, 12:34 PM
HeatherBelle HeatherBelle is offline
Junior Member
HeatherBelle is on a distinguished road
Default
I dont have an answer for you, but I think yours is headed in the same direction mine went. After the whole hesitation one day it started backfiring and running crappy. Then stop running. Won't start. I have replaced fuel pump and it's still doing same. I did not think of regulator though.
  #3
Old 01-17-2013, 01:02 PM
BALLSS BALLSS is online now
BALLSS
Default
the fuel pump 'regulator" can be checked by pulling the vac line off the back and closely look for any signs of wet fuel on that rubber nipple...if wet it is bad
__________________
\'96 BBB 383/T-56
  #4
Old 01-18-2013, 08:57 AM
M0U35Y's_SS M0U35Y's_SS is offline
M0U35Y's_SS is on a distinguished road
Default
^^^^ adding to the above, when my regulator went i never actually leaked into the vacuum line. it only leaked through the joint on the outside of the regulator. just fyi though.
__________________
96 impala ss
dd
133xxx and counting
first base delete
all led interior/exterior, dakota digital fan relay thingy.
door trigger radio do dad, r1 concepts rotors, monroe sensatrack shocks all around.
euro smokes on the front alteza smokes on the rear.
the more things change the more they stay the same
  #5
Old 01-18-2013, 11:37 AM
BALLSS
Default
and to add, run the car first then check the FPR nipple. Otherwise the gas may have evaporated if the car has been sitting.
__________________
\'96 BBB 383/T-56
  #6
Old 01-18-2013, 02:37 PM
infomanSS's Avatar
infomanSS infomanSS is online now
infomanSS
Default
Does it hesitate right when you push the pedal down, but then runs smooth...like when leaving a stop sign it hesitates then runs smooth? If so, I would lean toward the EGR valve.
__________________
David Shull
95 Impala SS
90 Cadillac DeVille
Forum Jump
(c) 2007-2011 Impala SS Forum
