Fuel pump issues. I think - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 01-17-2013, 12:15 PM
HeatherBelle HeatherBelle is offline
Junior Member
HeatherBelle is on a distinguished road
Default Fuel pump issues. I think
I am moving my thread from misc. to here. (Suggested). I few weeks ago 96 ImpSS Would run a little shoddy when cold. I thought tune up, but then one day it started popping, hesitating, backfiring. After that it just wouldn't start at all. She would just turn and turn. Checked all spark plugs and wires everything looked fine. Went on to fuel. I only put 94 high octane from shell. When key was put in ON position I couldn't hear fuel pump switch on and start prime. Now I have replaced fuel pump. And same ****. Won't run. Anyone have this problem before?
Old 01-17-2013, 12:37 PM
angelo's Avatar
angelo angelo is offline
angelo can only hope to improve
Send a message via AIM to angelo Send a message via Skype™ to angelo
Default
Step 1.
check schrader valve for proper fuel pressure. 37-42 psi
work backwards until you find why pressure is not up to par...
if pressure is good report back so.
-ALF out...
__________________
ECIRS #427 ISSCA #01978
96 WX3 DGGM Bone Stock except Bilstein 0929/1104 odom fade mod, FB, HP & muff delete, lower bushing mod,Stealth Brake Bolt mod,9C1 air dams,160 stat,Taylor wires,SStudio TB Boot & K&N,Bonnies
http://www.vimeo.com/1191344 CLICK ME !!!
http://www.cardomain.com/ride/2386222/1
  #3
Old 01-17-2013, 12:41 PM
Junior Member
Default
Thank you will do.
  #4
Old 01-17-2013, 12:53 PM
BALLSS BALLSS is offline
BALLSS
Default
I have found a $30 investment in a fuel pressure gauge for LT1 is worth it. That will instantly tell you if it is a fuel pressure problem. Hypertech makes one but assume others do also
If FP is good...I would look towards the Opti as you note "popping/backfire"...previously. That is a very common signal Opti is dieing or dead.
Unfortunately codes are not always thrown. You can buy a code reader for OBD2 cars (96 and newer) for around $30 also at places like Harbor freight.
FP gauge and code reader along with a Haynes service book can go a long way in resolving problems.
with all this said "your" problem could be so many things but fuel and spark are two initial things to confirm. hard parts can fail but things like poor connections can cause havoc in tracing WTF is really going on.
This forum is full of great help...and some sarcasim.....as you may have discovered in the Misc section.
__________________
\'96 BBB 383/T-56
  #5
Old 01-17-2013, 01:03 PM
streetcar2try's Avatar
streetcar2try streetcar2try is offline
streetcar2try is an unknown quantity at this point
Default
You can purchase a fuel pressure tester or alot of chain auto parts stores have them for rent. You will connect it to the schrader valve as in the pic above. Unscrew the black cap and install the tester.
You can then use that red wire I mentioned. That is just a jumper wire directly to the pump. That wire is used for testing and diagnostics, which you are doing. It will run the pump even if the key is off. When applying current to the pump, the gauge should read about 40-45psi. It should jump up almost instantly. If it takes more than 2 seconds, the pump is weak, it it doesn't reach at least 35psi, the pump is weak or shot.
If it is an ACD, it has a LTW.
__________________
94 ImpSS, 383 build in the works..........
  #6
Old 01-17-2013, 01:12 PM
Bad Imp's Avatar
Bad Imp Bad Imp is offline
Bad Imp is on a distinguished road
Default
^Great advice! We had a club member with the same problem, couldn't figure it out, so decided to change the Opti and whan we pulled it out we could hear rattleing, so took the cover off and foung both screws for the rotor had backed out and off.
__________________
Las Vegas Impala SS Club - SSincitySS.com
1996 Impala SS, Powerdyne Supercharger 6 psi, 3.73s, Snow Performance water/meth injection, Borla catback, F-Body MAF, Grotyohann long tube headers, Magnaflow cats, Hotchkis springs/front & rear sway bars, Bilstein shocks, Vigilante 3000 stall TC, Wilwood brakes, 20in Budnik Fontana's, and a couple of polished items
  #7
Old 01-17-2013, 02:36 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
as she has a 96 I would check for codes also, P0300 stored or active is common when the opti is starting to go.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #8
Old 01-17-2013, 06:21 PM
Junior Member
Default
Is is all great I formation. I will post back tomorrow with results. Thanks a lot guys, I found out the hard way to stay away from misc. section.
  #9
Old 01-17-2013, 08:36 PM
DougDePew DougDePew is online now
DougDePew is on a distinguished road
Default
If you need to start a fire, the Haynes manuals are indeed a great way to resolve a problem.
  #10
Old 01-17-2013, 08:49 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
I agree with the other posters, just one more piece of advice:
If you don't have a PCM tune to take advantage of it, filling these cars with premium gas is just throwing money away. Save a few bucks, it will run just fine on regular unleaded.
__________________
2005 Pontiac GTO
Forum Jump
(c) 2007-2011 Impala SS Forum
