fuel pressure - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #1
Old 01-20-2013, 11:25 PM
naSStyboy9c1 naSStyboy9c1 is offline
naSStyboy9c1 is on a distinguished road
Default fuel pressure
just wondering when is it needed to have a adjustable fuel pressure regulator?
__________________
Ecam racing engines
Old 01-20-2013, 11:46 PM
4x4high 4x4high is offline
4x4high is on a distinguished road
Send a message via Yahoo to 4x4high
Default
When you install a much larger cam, heads, and larger exhaust system that requires more fuel to make more HP along with an ECM tune.
  #3
Old 01-20-2013, 11:59 PM
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka is an unknown quantity at this point
Default
If you're not running nitrous.....don't bother. Stick with a stock, non-adjustable FPR.
KW
__________________
1996 BBB SS, 398ci SR
1995 DCM SS, 355ci
  #4
Old 01-21-2013, 05:57 AM
The Bolt-On Terror's Avatar
The Bolt-On Terror The Bolt-On Terror is offline
The Bolt-On Terror is an unknown quantity at this point
Default
None of the above; cam, heads, exhaust, nitrous, call for an AFPR ...... in my opinion.
Far less than 1% of the people running LT1 engines are doing the things that would call for it.
A long time ago, before I knew much about these cars, I ran one. Now I try to do things the right way.
Instead of going into the explanations, I'll first just ask: what are you trying to accomplish?
__________________
Stock bottom, AI topend
Built by B-Body Performance
NA: 10.98 @ 122
100 shot: 10.35 @ 128
2012 ISSCA Nationals SSuperPro Champion
  #5
Old 01-21-2013, 08:41 AM
RatSSled's Avatar
RatSSled RatSSled is offline
RatSSled has a little shameless behaviour in the past
Default
Perhaps he's installing a carburetor!
__________________
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
96 DGGM Wagon - Spun bearing, headed for the scrap yard!
  #6
Old 01-21-2013, 08:54 AM
Default
ya got me there!
  #7
Old 01-21-2013, 11:45 AM
GuillaumeC's Avatar
GuillaumeC GuillaumeC is offline
GuillaumeC is an unknown quantity at this point
Default
KW
Why would one need an adjustable FPR with nitrous?
__________________
Guillaume Charest
1995 DGGM Caprice, 355ci twin turbo, TH400, F.A.S.T. EFI, 4200 lbs street car 10.71 @ 128.6 mph
1989 Mazda RX7 Turbo II, 385ci LT1, LE2 heads/cam, T56
  #8
Old 01-21-2013, 02:22 PM
Ram Air 383 Ram Air 383 is offline
Ram Air 383
Default
When your fuel injectors are a bit small for the engine and you have fuel pump that is efficient at a higher pressure, an adjustable regulator can be used to prevent injectors from working overtime.
__________________
93 Mazda RX-7 - Heads/Cam LS1, T56 - sold
95 Chevy Caprice - Golen LT4 383, LE3 heads/cam - no more
  #9
Old 01-21-2013, 02:47 PM
Default
Having the regulator dialed down for normal street driving......and have the option of dialing it up when you're gonna spray.
Or so I've been told.
KW
  #10
Old 01-21-2013, 03:07 PM
GuillaumeC's Avatar
Default
Not sure I agree with that...
If you need a bump in fuel pressure when spraying then I think you have the wrong fuel jet size.
Just my opinion, I could be wrong.
__________________
Guillaume Charest
Forum Jump
(c) 2007-2011 Impala SS Forum
