Erratic idle - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 01-21-2013, 05:18 AM
Slayerdies's Avatar
Slayerdies Slayerdies is offline
Slayerdies is on a distinguished road
Send a message via AIM to Slayerdies
Default Erratic idle
Ok when I first start my car it idles low.
After bought 2 minutes idling the car idles up amd down and then cuts off.
If I jump right in back out my driveway and then hit brake it cuts off.
Once it warms up it doesnt do this anymore.
Thoughts?
I am thinking idle air control/tps..
__________________
96 BBB Impala SS
Auto Climate, F-Body EGR, Gary's Batt Cables, Break Bolts, 160hyperstat, TB Bypass, Home Depot Intake/Hockey Puck and SwissCheeseAirBox, Try Y Gen II's, Pypes Xpipe,,Dynomax UltraFlows, Sprints, C3extend with solid uppers, NitroDrop2s, TruTrac with 3.73s
Work In progress... On a tight budget
Parts Sitting In The Garage...
S-10 converter, Blazer overhead
Old 01-21-2013, 07:53 AM
chw9695's Avatar
chw9695 chw9695 is offline
chw9695 is on a distinguished road
Default
Try replacing the Liquid Temperature Sensor or the Air Temperature Sensor. The sensor may be bad because it is sensing it is too cold so it gives it more fuel to start the car initially. The low idle sound you hear may mean it is flooded as-well because the car injected all of that fuel. That may also explain why it starts easier when its warmer out. Hope this helps!
  #3
Old 01-21-2013, 11:16 AM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
Clean IAC. Check vacuum lines and ECT sensor.
__________________
2005 Pontiac GTO
  #4
Old 01-21-2013, 11:54 AM
infomanSS's Avatar
infomanSS infomanSS is offline
infomanSS
Default
Check the vacuum lines on the passenger side of throttle body. I had similar symptoms, bought IAC valve and discovered that one of the vacuum lines had rotted away and even ate away part of the metal fitting.
Fixed this by using silicone to "glue" hose back onto the vacuum fitting (let fully harden so that the silicone wouldn't be pulled into engine).
I didn't even have to take the TB off to fix this, but went ahead and removed and cleaned everything up anyway. I did not replace the IAC.
__________________
David
09 Town & Country Ariel
08 Silverado 4x4 Ruby
03 Avalon XLS Iggy the Fierce
00 Infiniti I30 Harleyquinn
95 Impala SS Marlene...SOLD
90 DeVille M...SOLD
  #5
Old 01-22-2013, 02:53 PM
Slayerdies's Avatar
Default
Ok I cant find any vaccum leaks.
ECT shouldnt effect this cuz it happens when car is cold and first started.
It has 162thousand miles on it with original IAC so I am leanning towards that.
__________________
96 BBB Impala SS
  #6
Old 01-22-2013, 03:16 PM
Slayerdies's Avatar
Default
Also wanna add.
Once the car is warmed up it idles steady.
__________________
96 BBB Impala SS
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
