Did I just blow a head gasket? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 01-25-2013, 08:41 AM
ocala's Avatar
ocala ocala is offline
ocala is on a distinguished road
Unhappy Did I just blow a head gasket?
Here's the story,
My SES light has come on and off intermittently for the last two days. I also noticed what seemed to be less power. Also a strange exhaust smell now and then.
So today, I get in the car and when I go to start it - KLUNK, tried three times, each time - KLUNK. I could tell that the starter was engaging properly, with torque. NOT a battery issue.
On the fourth time the engine started. Sounded OK but very slightly rough, like possibly a cylinder misfiring.
After it started, I quickly saw A LOT of whitish steamy smoke coming out of the exhaust. More than I have ever seen before.
I gently pulled it back in the garage and shut it down. Drove my F250 to work and here I am.
So does this sound like a blown head gasket?
__________________
95 DGGM 396 Stroker, Eagle crank & rods, LT4 heads, LT4 intake, LT4 hot cam, Finish Line long tube headers, 2 1/2" exhaust, Big Baer brakes, 3.73 rear, Hotchkis lowering springs, Front and rear Hotchkis Sway bars, aluminum driveshaft, Metco aluminum boxed trailing arms, K&N, Gary's Cables, 42# Green Giants, T84's,T56 Magnum
Old 01-25-2013, 09:31 AM
95Chwagon's Avatar
95Chwagon 95Chwagon is offline
95Chwagon is on a distinguished road
Default
I think you answered your own question. Any amount of white smoke isn't a good thing. Another sure sign is losing coolant or rising temperature.
Is it both exhaust pipes? If it is only one, at least you only need to rework one side. Hopefully you caught it soon enough before you warped the heads.
__________________
The Good - 92 RMW, Layin Wood on Billet Boyds
The Bad - 95 Chwagon, Pill Popper, Looking for 11s
The Ugly - 95 Cappy, Retired California Cop BBHP-120
  #3
Old 01-25-2013, 10:11 AM
ocala's Avatar
Default Can't say which side
I have what is like a Y pipe, exhaust goes from two to one 5" and back to two. I guess I could pull the exhaust and see which side...
__________________
  #4
Old 01-25-2013, 10:14 AM
ocala's Avatar
Default
Regarding catching it before it warped the heads, could this be why the car wouldn't turn over the first three times?
There was NO overheating. I think the water level is OK, but I won't know untill I get home.
__________________
  #5
Old 01-25-2013, 10:22 AM
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka is an unknown quantity at this point
Default
Originally Posted by ocala View Post
Regarding catching it before it warped the heads, could this be why the car wouldn't turn over the first three times?.......
Probably didn't start because you had coolent in the combustion chambers of the head that blew the gasket.....of coolent in the cylinder(s) on that bank.
You're lucky you have the steam coming out the exhaust.....I broke three starters (those KLUNKS can be killer ) before we determined that I had a blown head gasket.....never had (or at least, noticed) the white exhaust like you did.
Good luck!!
KW
__________________
1996 BBB SS, 398ci SR
1995 DCM SS, 355ci
  #6
Old 01-25-2013, 10:43 AM
Barbarossa's Avatar
Barbarossa Barbarossa is online now
Barbarossa is an unknown quantity at this point
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
Default
__________________
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
  #7
Old 01-25-2013, 11:47 AM
infomanSS's Avatar
infomanSS infomanSS is online now
infomanSS
Default
Yep, I think that you blew a head gasket. Pulling the spark plugs should show which bank needs to be fixed.
On the bright side, it's a great opportunity to upgrade cam / heads / rockers / etc.
Good luck!
__________________
David Shull
95 Impala SS
90 Cadillac DeVille
  #8
Old 01-25-2013, 12:17 PM
ocala's Avatar
Default
Originally Posted by infomanss View Post
on the bright side, it's a great opportunity to upgrade cam / heads / rockers / etc. :d
good luck!
just what i was thinking:d
__________________
  #9
Old 01-25-2013, 01:14 PM
luckydriver luckydriver is offline
luckydriver is on a distinguished road
Default
i blew one last year driving and didnt know it..my temp gauge was broken and only after it shut dont did i realize oops...
funny thing is it was towed home and started right up and i was able to drive it up the driveway (tow guy coudlnt get up the hill)
we took out a plug and watched the stuff pour out..soup everywhere..not fun
also cooked all the oil and heard a noise on the lower end of the motor so decided on a rebuild
i have a new ATK engine now and i'm very happy and just rebuilt the tranny 2 weeks ago i have a brand new car!
__________________
95 DCM 224K stock except for Borla...new engine in at 224K in 8/2012 with TONS of new parts......87 caprice became my snow car in 2000 and it was laid to "rust" in 10/07 with 338K. Rebuilt trans at 308,000 (lasted pretty long I think); new radiator 330,000 (they said it literally disintegrated when they took it off); SS better last at least that long
  #10
Old 01-25-2013, 01:15 PM
ocala's Avatar
Default
What is an ATK engine? Thanks
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
