#1
Hey Guys,
Yes, I know I've had a couple t56 cars and have always preached at least 4.10's but preferably 4.56's... But has anyone done it with 3.42's? I'm looking for cruising rpms at highway speed. I run a 26" tire. I have plenty of motor, and this will be a pleasure use vehicle, with much commuting duty, and it already has recent 3.42's. I'm assuming 6th will be useless under 65mph, and that's fine with me. I'm hoping the highway rpms from 70-80mph will be less than 2K rpms so I can get some really decent mileage out of it. Also, how was it getting it going from a stop? I've driven 3.08 and 2.93 cars with the t56 and it felt fine to me. I know someone had put together a spreadsheet with the differsnt trannies and gear ratios and tire diameter to find rpm, but I can't seem to find it now. Anyone still have it, or a link to it? Thanks guys! Catcha later.
__________________
Bill "The Verb" Crovo - Resident Car Slut ![]() 95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner... 00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc... 94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said. American Ricer www.badassofne.net "Ooooh! Look! Something shiny!" LOWER IT!!!
| Sponsored Links | ||
Advertisement | ||
#2
I think the stock gears for F bodies with T56 was 3.42. You'll be fine.
__________________
Old cars, just like classic rock... 60s, 70s, 80s, and 90s! |
#3
3:42 may work. the F bodys came with 3:42 with the T56
with that said the B-body weighs quite a bit more than a f body my experience was with 3:73. It had a slight "dog" feeling off the line and even more so starting uphill so went 4:10 I suspect the 3:42's even more doggish off the line and would require more clutch slip to get going. Guy out here in SoCal did T56 swap years ago with 3:08's, burned up his clutch in a year or so of normal driving smokemup.com has a calculator if 3:42 you would never see 6th gear under 80 mph without lugging the car. with 4:10 at 80 mph I tach 2k rpm with a 27" tire so I leave it in 5th at 65 mph and tach about 2100 at the track I run a 26" tire so gear ratio then is 4:xx? (lower ratio than 4:10)
__________________
\'96 BBB 383/T-56 |
#4
Yeah, I knew the fbodies came with the 3.42's and a 26" tire, but as stated, I'm about 1200 pounds heavier than those. And with 4.10's, I would use 6th gears as low as 50mph, with a 26 or 27 inch tire, with no issues for cruising.
Thanks for the calculator link. I'll check it out when I get home.
__________________
#5
Here's the one I found on this forum: http://www.impalassforum.com/vBullet...d.php?t=233667
__________________
![]() 95 9C1: AI 190cc Heads/cam, 355 Bottom End, 58mm BK TB, Intake Ported by AI, CIA Quad-1 Long Tubes w/ Export Pipes, Beefed up 4l60 w/ Yank SS3200 TC, 3:73s, Eaton Truetrac, SS Rearend, Eibach Springs, Bilstein Sport Shocks, PPM Front End, C3Fab 5/8 Extended Control Arms, SS Interior... 53 Studebaker Starliner: Lowered (not enough). That's it. |
#6
What ya puttin it in?
__________________
1995 9C1 06 CTS-V 1972 C10 shorty 1969 C30 Wrecker. |
#7
http://craig.backfire.ca/pages/autos/speed-calculator
26" Tire, 3.42, T56 with 0.74 & 0.50 OverDrives RoadMpH … 5th: 2.53 … 6th: 1.71 46MpH ………… 1503 ………… 995 54MpH ………… 1765 ………… 1169 61MpH ………… 1994 ………… 1320 69MpH ………… 2255 ………… 1493 77MpH ………… 2516 ………… 1666 84MpH ………… 2745 ………… 1818 92MpH ………… 3007 ………… 1991 Fwiw: 4L60E * 2.56 3rd: 2.56 vs your 5th: 2.53 4th: 1.78 vs your 6th: 1.71 If my [enervating] experience with 2.56 is any indication, your 6th gear will provide negligible highway acceleration without the assistance of a tailwind, a draft, or a downhill … or … more torque in the 1000-2000 RpM range than our LT1. IMO, with a T56'd B-car, 3.73 would be the bare minimum, unless highway MpGs were the ultimate goal, or I had a more torquey engine than the mid-90s ironhead LT1. With either 3.73 or 4.10, the extra gear could be mitigated with tires as tall as 29", which would add more rubber to grip the road.
__________________
OPTION-LESS 94 Chevy Caprice Classic Wagon … GU6 & G80 … PCM Performance … NO OIL COOLER, JUST 0W40 … TB-IAT-MAF-Filter-Inline intake + heatshield … Monroe Severe Service 550012 & 550013 Shocks … BMR 1.26" Solid Front Swaybar … WP118HD … MAF Sensor DISabled, Speed Density Calibrations in progress … 160°F Summer tune or 180°F Winter tune …
#8
I drove my 3.08's to nationals. It wasn't ideal but they worked, for the month I had before all the rear end parts arrived. I would guess 3.42's would be doable if you don't mind slipping it a fair bit. With 3 08's and 6th gear at 75 on a stock motor if I remember correctly I pulled down something like 28-29 mpg.
-Brian
__________________
'95 B4U T56 in Purple Pearl with a few add-ons. Currently dead. Engine block is at the machine shop and it should hopefully be back on the road mid June. '63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags. '06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me. Still in Wichita. |
#9
IMHO, if the T56 is going in the long roof car....4:10's. The "cruise & hwy" will be way happy with 5th or 6th gear but more important is the car will not bog off the line or be a bitch pulling from a dead stop up a hill or driveway
the 3:42's will "work" in terms of just being able to drive the car but the 1200 lb weight over the f-body weight will reveal the fact you need more gear......and your clutch will last longer
__________________
\'96 BBB 383/T-56 |
#10
OK, that's all about what I figured. Thanks guys.
I know that I really want 4.56's, but was curious if the 3.42's would be do-able for mileage concerns. My motor is NOT stock, so if I had any shot at increasing the mileage, I was gonna take it. I've got plenty of time to think on it...
__________________
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
