Driveline shake in 4th, related to load - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 01-28-2013, 12:32 PM
The Lazy Destroyer's Avatar
The Lazy Destroyer The Lazy Destroyer is offline
The Lazy Destroyer
Default Driveline shake in 4th, related to load
'94 RMW
Car has a shake at approximately 75 mph. Feels/sounds exactly like when you hit the rumble grooves on the breakdown lines on the interstate, so it's pretty prominent. It's not exactly speed related, more so load related. So for example, cruising it may happen at 75 mph on a flat level. But may happen at 70-72 if going slightly uphill, or happen at 80 if going downhill.
So the speed it happens will vary to match the load if you are trying to keep a constant speed. Once it happens, if you immediately get completely off the gas, or get into the gas to increase the load on the driveline... it goes away immediately.
But it does not happen below 68-70 at all. Seems if you keep it above 80-85 it goes away but to be honest I don't drive that fast regularly to know for sure.
Feels like it comes from the center or maybe the rear of the vehicle but to be honest it's kinda hard to pinpoint exactly, and it's too strong to really want to stay in it to tell.
Previous owner said it happened with another set of wheels/tires so I do not think problem is there.
Any thoughts what this may be based on the description? Or anything that can be ruled out? I just got the car and will probably take it to my mechanic for a once over but curious what this may be.
I did a quick search and a couple threads had a very similar description but no resolution was posted
__________________
-Blake
"Those who possess power define those who are powerless."
95 Caprice 9C1, 13.1 @ 101 mph, 1.720 60' - Bolt-ons car
Old 01-28-2013, 12:35 PM
Barbarossa's Avatar
Barbarossa Barbarossa is offline
Barbarossa is an unknown quantity at this point
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
Default
My guess.
(five posts below your post)
Advantages of a larger aluminum driveshaft over a stock one?
Originally Posted by The Bolt-On Terror View Post
Critical speed.
The lighter mass and larger diameter results in a higher critical speed (the rpm at which the shaft reaches its first bending mode natural frequency and turns into an oscillating jumprope).
Since you have 3.73 gears, at your cars top speed your driveshaft can reach an rpm exceeding that critical speed, and bad things can happen. Not WILL happen, but CAN happen. If everything is perfect on your car - ujoint angles, driveshaft balance, you might get lucky and never have a problem. The odds of that are probably less than 50% if you drive it at high speed.
Never exceed 110 mph, and you probably won't have an issue with the stock one.
__________________
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
  #3
Old 01-28-2013, 12:45 PM
The Lazy Destroyer
Default
Stock 2.93's and I thought those issues were related to driveshaft speed and not load.
Am I misunderstanding the driveshaft issue when going to higher gears then? Is that similar when it's load related? I always thought DS issues like balance would be worse once it started if you sped up?
In the excerpt you quoted:
"Never exceed 110 mph, and you probably won't have an issue with the stock one"
This does not seem related to my issue. Every time it happens I can get it to go away if I just snap on the gas (change load) and it will go away before the car even gets a chance to change speed. Does not seem to happen at higher speeds since the load required to maintain it is higher than the load this problem happens at.
__________________
-Blake
  #4
Old 01-28-2013, 01:09 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
I would check the usual suspects.
trans tail bushing play
condition of all u-joints
motor mounts
rear control arms condition and bushings
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #5
Old 01-28-2013, 01:14 PM
eagle-co94's Avatar
eagle-co94 eagle-co94 is offline
eagle-co94 is an unknown quantity at this point
Send a message via Yahoo to eagle-co94
Default
Here's an added bit of info:
When towing an empty Uhaul flatbed trailer the vibration did not exist. After loading a roughly 2500 lb car on said trailer, there was also no vibration. It only happens when not towing.
Rear diff fluid is new (maybe 1000 miles) with the proper gasket and 2 bottles of GM additive.
__________________
James _ _ _ _ _ _ _ _ _ _ "Power tends to corrupt, and absolute power corrupts absolutely." - Lord Acton
96 BBB SS - BBHP #123-4.56
72 Chevelle Wagon FOR SALE $6k
04 MINI Cooper S (hers) FOR SALE $5k OBO
10 SRT8 Challenger . . . 81 DeLorean DMC-12 . . . 85 Austin Mini - RHD on 10's
ISSCA #1830...expired
  #6
Old 01-28-2013, 01:41 PM
Mr pogo's Avatar
Default
I shoulda added it (meant to but just woke up) but check driveline angles.
especially when a load changes the symptoms.
__________________
  #7
Old 01-28-2013, 04:27 PM
DougDePew DougDePew is offline
DougDePew is on a distinguished road
Default
u-joints
  #8
Old 01-28-2013, 04:59 PM
MillerTimeGS's Avatar
MillerTimeGS MillerTimeGS is offline
MillerTimeGS is on a distinguished road
Tap the break pedal. See if it stops.
Sent from AutoGuide.com App
  #9
Old 01-28-2013, 05:05 PM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is offline
Navy Lifer is an unknown quantity at this point
Default
Originally Posted by The Lazy Destroyer View Post
'94 RMW
Car has a shake at approximately 75 mph. Feels/sounds exactly like when you hit the rumble grooves on the breakdown lines on the interstate, so it's pretty prominent. Once it happens, if you immediately get completely off the gas, or get into the gas to increase the load on the driveline... it goes away immediately.
Long shot, but check the harmonic balancer at the front of the engine.....
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
Forum Jump
(c) 2007-2011 Impala SS Forum
