#1
Could it be the water pump.. I got up the other morning too a slushy radiator hose !!! Damn previous owner didn't have enough antifreeze in it !!! car warms up but is still no heat temperature go up slowly and it pushes fluid out the overflow tank..help ASAP!
__________________
96 CAPRICE SS PROJECT 94 CAPRICE CLASSIC SOLD Last edited by jaywill; 01-28-2013 at 01:08 PM. |
| Sponsored Links | ||
Advertisement | ||
#2
Not sure that I have ever heard of the waterpump not working. Typically they just leak when going bad. It is mechanically driven and I would think even if it was pure ice, the ice would crack before the steel splines would. I've never taken a waterpump apart to inspect the innards but I would suspect the propellers are made out of steel too.
More than likely what happened is the lines froze, so the coolant wasn't getting past the ice to actually bring new coolant into the block. You were not getting any heat of the heatercore because it is frozen too. Hopefully adding some AF and letting the lines thaw out makes the problem go away.
__________________
1994 SS - GRAIL President & Webmaster, St. Louis, MO
View our Tech/Guide page for everything from your basic oil change to Manual transmission swaps! ![]() |
#3
Slushy? If the lines were "slushy", it sounds like you may have been very close to possibly popping the freeze plugs and maybe something worse if the block froze.
Not sure what your temps are for winter in your location, but it sounds like you are already questioning the previous owners maintenance schedule. Just for piece of mind, I would recommend you flush ALL the coolant (pull the knock sensors) from the system and flush the heater core as well. Then top it all off with a 50/50 mix of green and Distilled water. Be sure to bleed the system afterwards and enjoy the toasy cabin that you will have along with the piece of mind that the block wont freeze. Figure 2 gallons of coolant and 2 of water for a complete flush. PS - Good time for a new T-Stat too. PS#2 - If the system was negleted for a while, may be a good idea to replace the restrictor valve on the heater hose and get a new plastic T fitting or consider making one out of metal.
__________________
================================================== ============= '95 Caprice SS conversion - Bonny Buckets - 96 Column, Shifter and Console - 3.73 Gear and Herter tune - Z/28 Cluster - Blazer OH Console - Green/Pink bushings - Chromed Impala Wheels - Eibach Springs and Bilstein Shocks - Corvette Engine Dress - the list goes on and still more to do...it never ends. Last edited by 4DoorSS; 01-28-2013 at 02:32 PM. |
#4
Thanks guys ..the temps got down into the 20's that night.. what could I do too thaw it out ? I have been cranking it and letting it run untill the temps get have way and letting it cool back down..
__________________
96 CAPRICE SS PROJECT 94 CAPRICE CLASSIC SOLD |
#5
some times the wp coupler/shaft splines are so worn out a load on them strips it.
or the press fit impeller is loose on the shaft. you could pull the wp cover and check it.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog BH tuned PCM
#6
You can pull the knock sensors, hopefully some stuff comes out. If not you might have to take a screw driver and poke around a bit. remove the T-Stat and run water through the system. Replace with 50/50 coolant mix and bleed the system of air.
__________________
#7
Another problem I have seen a few times is the collar between pump and shaft strips out. I think I have 3 or 4 in a box I use for misc. spacers.
__________________
94 ImpSS, 383 build in the works.......... |
#8
OP
it sounds like your coolant/water froze.... starting motor and trying to thaw it out that way may prove to cause damage as water can't circulate. if you can hook up a hose to your hot water heater, pull T stat and knock sensors maybe you can flush it with hot water. same for radiator. and not to be a dick...but once you bought the car it's 'maintance" became your responsibility which would include fluid levels and condition.
__________________
\'96 BBB 383/T-56 |
#9
I was going to say this also. Who doesnt check and refill most if not all fluids after a car purchase?
Anyways, the above advice is spot on. It probably froze on you.
__________________
95 DCM Imp SS....Daily Driver 98k and counting 72 Cutty............Weekend cruiser. |
#10
I check the coolant when I got it and it looked like it had enough .. but I was wrong ... it should have done thawed out by now..i gust.. I can squeeze holes in hear water moviing in the heater hose and both radiator hose
__________________
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
