| Register | Garage | Photo Gallery | FAQ | Members List | vBClassified | Googlemap ME | Calendar | Search | Today's Posts | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
#1
cleaning the engine bay the other day came across what looks like a T fitting with a check valve in the air pump hose. this is right by the abs unit I capped it off sense I have not a clue if a hose hooks up to it or where it goes? anyone help me out here ?
| Sponsored Links | ||
Advertisement | ||
#2
It would help if you told us what year, model and engine type you have and include a picture if you can.
Attached is a link to the air pump setup on a 95 lt1/ l99,.... http://parts.nalleygmc.com/showAssem...rimLevel=15486
__________________
================================================== ============= '95 Caprice SS conversion - Bonny Buckets - 96 Column, Shifter and Console - 3.73 Gear and Herter tune - Z/28 Cluster - Blazer OH Console - Green/Pink bushings - Chromed Impala Wheels - Eibach Springs and Bilstein Shocks - Corvette Engine Dress - the list goes on and still more to do...it never ends. |
#3
94 , impala , lt1 , photo is already in the above post
#4
Uhh......no, it doesn't seem to be
__________________
1996 Impala SS #3 |
#6
#7
Just a bump in my thread, can anyone trace the hose to item number 20 in the above diagram to find its location, I poked around under the hood and couldn't seem to find a loose solenoid or wiring. |
#8
on the crossover tube that runs under the engine for the air system on the driver side, the solenoid is attached via a clip to that tube, a small diameter vacuum hose runs from that check valve to the solenoid
look by where the spark plugs leave the opti on the driver side there is a 4 prong plug in a little solenoid
__________________
Bigb9000 is a scammer, you owe me 3 MAP plugs 1996 ss BBB 72k see my build yes its loud and fast 1996 ss BBB 182k 1996 caprice candy green ninja turtle mobile 1995 ss BBB daily driver 165k 1981 Malibu 1985 Regal and wifey made me buy the venza truck 20k
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
