Extended Wheel Studs? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Wheels & Tires
Thread Tools Display Modes
  #1
Old 02-04-2013, 06:08 PM
ekm1190's Avatar
ekm1190 ekm1190 is online now
ekm1190 is on a distinguished road
Default Extended Wheel Studs?
Hey guys I've been talking with 94MI9C1 about some extended wheel studs and he thought these Moser studs might work, can anyone confirm?
LINK: http://www.summitracing.com/parts/msr-8255/overview/
I'm purchasing either 3/8" or 1/2" hub centric wheel spacers so i need longer studs in order to properly fit the lug nuts.
If anyone knows of any better options please let me know.
-Evan
__________________
Indiana B-Bodies, JOIN Hoosier INC!!
Build Thread: FORM = FUNCTION
Old 02-04-2013, 10:13 PM
PurpleSStripes's Avatar
PurpleSStripes PurpleSStripes is online now
PurpleSStripes
Send a message via AIM to PurpleSStripes
Default Arp 100-7708
Those will work just fine.
FWIW, I always use ARP part #100-7708, also available at Summit Racing.
When you install on the front rotors you will notice that the ABS tone ring gets in the way of the new studs dropping into to place. Instead of trying to removing the ABS tone rings, use a bench grinder to make a small notch on the side of the new studs head. A small notch is all you need to get enough clearance.
When you install on the rear axles, you will need to remove the rear differential cover, pull the C-clip and slide the axle out an inch or two to get enough clearance.
__________________
Garry Forman
Midwestern Council of Sports Car Clubs High-Speed Autocross Series Class Champion - 2003, 2004, 2006
mailto:garry @ connersforman . org
DARE to Resist Fords and Imports
ISSCA #327
Last edited by PurpleSStripes; 02-04-2013 at 10:15 PM. Reason: spelling correction
  #3
Old 02-04-2013, 10:52 PM
ekm1190's Avatar
Default
thank you for the info, ARP defiinitely has a great reputation. I'm assuming the ones you listed are extended far enough for the max of 1/2" extension? Just double checking before I go ordering any. Also, i've taken the rear diff cover off and changed the gasket before so that's no issue, but i've never dabbled in the actual axle shafts area. Any advice/pics/instructions you can give? I'm not sure where this C-clip is you're referring to.
__________________
  #4
Old 02-05-2013, 12:37 AM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is offline
Navy Lifer is an unknown quantity at this point
Default
This should get you through it
and some pix would help....
How to remove a C-clip rear axle
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
  #5
Old 02-05-2013, 10:49 PM
ekm1190's Avatar
Default
So from what i'm seeing is I almost have to disassemble half of the rear diff before I can even get to the c-clips to pull the axle shafts out? The scariest part about this, to me, would be re-installing the spider gears, because of the one in the back. Although the spider gears can only go in a certain place thanks to the spider gear shaft...
Would it be a good idea at this point to wait and install new gears (3.73 planned) when I do this? I don't want to make it more complicated than it should be, but i'll have a lot of it already removed (judging from this video)
__________________
  #6
Old 02-06-2013, 07:39 AM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
The only part that needs to come out is the cross-pin. This allows the axles to slide inward enough to remove the clips with a magnet,or needle-nose. Checking for wear/damage in the axle bearing area would be prudent also.
  #7
Old 02-06-2013, 11:57 AM
PurpleSStripes
Default
I assume you have a LSD? Take a look at the ehow video in the links Bill posted. This shows the procedure on car with a posi rear end.
Garry
  #8
Old 02-06-2013, 12:09 PM
1slow96's Avatar
By the way,ARP also offers wheel studs for our cars in 3.5" length. As well as the 2.5",stock is 1.5". I use/recommend the 2.5",and run 1/2" spacers in the rear currently. If I had it to do over I'd get the 3.5" in the rear,but was worried about clearing the center caps. They wouldn't have even come close.
  #9
Old 02-07-2013, 09:27 AM
sonuvah's Avatar
sonuvah sonuvah is offline
sonuvah
Default
I don't understand why the wheel adapters are not considered here. The studs and spacers can be customized to your desired specs. I'm running them now without issue. Would be a lot less work than r/r studs.
https://www.motorsport-tech.com
__________________
Latest Mods: Hood vents, grille, black paint
  #10
Old 02-07-2013, 10:23 AM
ekm1190's Avatar
Default Re: Extended Wheel Studs?
They were definitely considered. However, this car is, for lack of a better word, abused. Drag strip, auto x, and road course. With an adaptor only 10-12 mm thick, there's no way I'd trust them to hold up under all that.
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
