Lights all night - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 02-11-2013, 11:43 AM
omahnc's Avatar
omahnc omahnc is offline
omahnc is on a distinguished road
Default Lights all night
I think I have a ghost or something in my car because my interior lights come on when they want to .. LOL, but seriously my dome and interior lights flicker on and off while im driving and I can her a noise like electrical wires are touching. At first I thought it was the fuse so I replaced it, and after a while it started back up. Also my odometer dims in and out and my fuel gauge jumps all over the place. Anybody have any issues like this?
__________________
1981 Impala "Shakira" ....350 Modded (sold)
1996 LS6/t56 DCM Impala SS "Caitlyn" .... work in progress
1996 BBB Impala SS "Ariana" (sold)
1996 416 Stroked LSA BBB Impala SS "Black Pearl"
Houston
Old 02-11-2013, 12:19 PM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
check grounds, theres one behind left kick panel I believe.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #3
Old 02-11-2013, 12:58 PM
omahnc's Avatar
Default
Okay, i'll try that and see if that helps
__________________
Houston
  #4
Old 02-16-2013, 10:41 AM
Jim Spahr Jim Spahr is offline
Jim Spahr is an unknown quantity at this point
Default Interior lights are module controlled.
There is a small module on my 94 Impala SS that controls the 'auto dimming feature' of the interior lights when the car is shut off. Mine would not cut off the lights. IOW they never went out. They wouldn't come on afterwards. However I would check this module-approx. 4" by 5" green plastic box. It was in the kick panel in either the front driver's or pass. side-- it has been so long, I don't remember exactly. I THINK it was on the driver's side. If cleaning carefully with alcohol doesn't work, replace it. In the meantime, pull that fuse so you won't run down the battery.
Please note! You didn't mention what year and model B car you have and this does make a difference in the problem and solution.
  #5
Old 03-03-2013, 06:23 PM
omahnc's Avatar
Default
I apologize...its a 96 impala ss..the electrical flickering has stopped. However, I still have an issue with my fuel gauge malfunctioning. I can hear the fuel pump priming when i turn the key so i don't think it is my pump. Im not sure if this is the sending unit or not.
__________________
Houston
  #6
Old 03-04-2013, 01:03 AM
Mr pogo's Avatar
Default
check the grounds by the trunk hinges and the ones in the engine compartment that go to to the fender by the battery and driver side firewall from cylinder head.
if theres still a gauge issue read the fuel sender refurb thread in the sticky.
__________________
  #7
Old 03-04-2013, 02:49 AM
Whisperjet's Avatar
Whisperjet Whisperjet is offline
Whisperjet is an unknown quantity at this point
Default
Also check the pin switches that are in the door jambs . . If the rubber boots are gone, they could be rusted and shorting out
__________________
Howard Rothstein
1996 Impala SS Signature Series
ISSCA Member 00147 (Founding Director)
NAISSO Life Member 1907
DeepSouthSS
Atlanta INC
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
