Race wheel questions - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > General Topics > Impala SS/B-Body Racing
Thread Tools Display Modes
  #1
Old 02-14-2013, 01:00 PM
subssonicimpalass's Avatar
subssonicimpalass subssonicimpalass is online now
subssonicimpalass
Default Race wheel questions
I'm looking at buying some drag racing wheels. What kinda backspacing do I need? Also is 10" wide a good width to go with?
Here is one of the wheels I was thinking about. Trying to keep the price down.
http://www.summitracing.com/parts/sum-85-5173/overview/
What do you guys think?
Do you guys have suggestions for tires?
__________________
'95 DCM Impala SS 125,000 miles
Jax INC
CAI, no cats, 2.5" exhaust with flowmasters and H pipe, 4.11 gears, Eaton posi, PCMFORLESS tune, airpump delete, bonnies, lowered on 22"s, tinted tails, GEN 2 Tri-y's, extended upper and lower rear control arms
New motor under way!!
Old 02-14-2013, 01:06 PM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
I'd send a PM to Mike Harris (1FAST94) he has studied this subject exhaustively,and I'm sure he would share his recommendations with you.
  #3
Old 02-14-2013, 01:16 PM
Barbarossa's Avatar
Barbarossa Barbarossa is offline
Barbarossa is an unknown quantity at this point
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
Default
Then please post up what Mike tells you!
__________________
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
  #4
Old 02-14-2013, 01:56 PM
1FAST94's Avatar
1FAST94 1FAST94 is offline
1FAST94 is an unknown quantity at this point
Default
I got your PM. Try to stay with factory wheel offset to keep the tire under the car. For 8" wheels, a 4" backspacing will work and is popular. For 10" wheels you need a 6 1/2" backspacing, but 6" would work. If you run 10" wheels you'll have to be careful what tire you use so as not to rub inside and may need some thin wheel spacers. I have notched my framerails and use a 10" wheel with 6 1/2" back spacing and can run whatever tire I want. Pat Gish uses a 10" wheel with the same offset with a smaller tire ans stock framerails.
__________________
Mike Harris
B-BODY PERFORMANCE
NA: 10.434 @ 126.95
94 Impala SS @ 3800 lbs
If you have ANY WEIGHT ON THE FRONT WHEELS AT ALL, that’s just wasted force that’s NOT on the rear tires
http://www.youtube.com/watch?feature...&v=a8dYCl2cAdM
  #5
Old 02-14-2013, 02:15 PM
subssonicimpalass
Default
Thanks for the reply. If I go with the 10" with 6" backspacing, how wide of a tire can I go and be safe? (no rub)
__________________
Jax INC
  #6
Old 02-14-2013, 05:58 PM
Leadfoot Leadfoot is online now
Leadfoot is an unknown quantity at this point
Lightbulb
I run 15x10 Holeshot Holestar's with a 6" BS, and 28x10 Hoosier slicks, and they fit just fine.YMMV This is with non-centered axles, and stock ride height.
__________________
SSeeya,
Bob Dannelley
95 409-DCM-11.839@115.10-NA,4350#
2011 Cheby Crewcab 6.2 Maxtow
2011 Caprice PPV 9C3-Maggie-500RWHP!
  #7
Old 02-17-2013, 12:57 PM
Lance's Avatar
Lance Lance is online now
Lance is an unknown quantity at this point
Post
If you can not afford aluminum lightweight wheels these are a nice alternative starting at $79: Bassett D-Hole Lightweight steel wheel
15x8 with 4" backing spacing weighing 17lbs each.
__________________
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
13.16 @ 103, CC 502, CPT 3, Edge 3400, 4.10 gears
96 SS:
11.74 @ 117, ERE #26 383, LE2 heads, AI 234/242, CPT 3, Yank 3600, 3.73 gears, PCM4Less.
12.28 @ 110, Golen 383, LE2 heads, Comp 503, CPT 3, Yank 3600, 3.73 gears, PCM4Less.
13.07 @ 101, Rebuilt LT1, LE2 heads, Crane 227, CPT 3, Yank 3600, 3.73 gears, PCM4Less.
14.11 @ 95, Stock LT1, Edge 3000, 3.73 gears, PCM4Less.
95 Caprice Wagon
  #8
Old 02-17-2013, 03:08 PM
ssimpala ssimpala is offline
ssimpala
Default
Do you think these would be strong enough for a daily driver?
  #9
Old 02-17-2013, 06:02 PM
Lance's Avatar
Default
I bought the Bassett Armor Edge wheels that are DOT and 19 lbs for 15x8s.
The wheels require 45 degree conical lug nuts.
Check out these lightweight aluminum lug nuts.
  #10
Old 02-22-2013, 06:21 PM
The Lazy Destroyer's Avatar
The Lazy Destroyer The Lazy Destroyer is offline
The Lazy Destroyer
Default
What do something like the 15x10 Holeshot Hole Stars weight in at?
__________________
-Blake
"Those who possess power define those who are powerless."
95 Caprice 9C1, 13.1 @ 101 mph, 1.720 60' - Bolt-ons car
Forum Jump
(c) 2007-2011 Impala SS Forum
