Rear end bad... - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 02-14-2013, 07:27 PM
fast lt1 fast lt1 is offline
fast lt1
Send a message via AIM to fast lt1
Default Rear end bad...
Well my side gears inside my rear end are wearing out i believe. The axle has play in it and you can pull it out and push it in a 1/4'' or more. I don't want to drop $1,000 on a rear end, so what route should i go. My auburn is also wore out and non working. I also wouldn't mind having a new ring and pinion gear set put in like 3.73's. Anyone know of any quality rebuild kits for the rear ends?
Old 02-14-2013, 07:58 PM
1slow96's Avatar
1slow96 1slow96 is online now
1slow96 is on a distinguished road
The factory Auburn is not re-buildable. I use/recommend the Eaton,but many like the TruTrac also. There is no inexpensive way out really. This is a good time to change the gear,this will actually save some labor. The Eaton uses a slightly different carrier bearing. You should change all the bearings anyway. Inspect the axles too. You won't regret going with the 3.73, that gear will really wake up your ride.
  #3
Old 02-14-2013, 08:41 PM
fast lt1
Default
What is the cheapest posi to go with? Also any reputable place to buy a set of 3.73's? And lastly what kind of stall should i run with 3.73's? Car sees a lot of highway driving. I'm running a small cam, which it needs a stall anyway cause my bottom end sucks when launching. I'm about to rebuild my trans so this is also a good time for a stall converter.
  #4
Old 02-14-2013, 10:29 PM
1slow96's Avatar
I use/recommend a quality 9.5" converter. They are not inexpensive,but they're worth every dime. Plus,it isn't something one wants to do twice. I'm very happy with the 3000 stall Vigilante. I have stock heads/cam,headers,and 3.73 rear gears. My 60' times at the dragstrip are under 2sec.
  #5
Old 02-15-2013, 12:14 AM
fast lt1
Default
I was thinking a yank 2200.... Is 2200 too low?
  #6
Old 02-15-2013, 09:19 AM
1slow96's Avatar
Is it better than what you have? Yes,but I find the 3000 Vigilante to be a vast improvement over the 2500 TCI installed previously. There would have been considerable savings if I had purchased the Vigilante to begin with.
  #7
Old 02-15-2013, 09:32 AM
Sshockr Sshockr is online now
Sshockr is an unknown quantity at this point
Default
I spent 1000 rebuilding my rear end 3 years ago with an Eaton, gears and an install kit. I did the install myself.
I would go bigger than 2200. I have 2400 in truck (got the converter for free) can't really tell much of a difference. Having driven well tuned 3200 and 3600 cars I wouldn't hesitate to go 3000 or bigger for a near daily driven street car.
-Brian
__________________
'95 B4U T56 in Purple Pearl with a few add-ons. Currently dead. Engine block is at the machine shop and it should hopefully be back on the road mid June.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
  #8
Old 02-15-2013, 09:49 AM
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka is an unknown quantity at this point
Default
Yank makes a 2200 stall TC for GM cars ???
If they do.....it ain't on their web site.
KW
__________________
1996 BBB SS, 398ci SR
1995 DCM SS, 355ci
  #9
Old 02-15-2013, 12:04 PM
BALLSS BALLSS is online now
BALLSS
Default
you start out saying you don't want to "drop a $1000"....but go on to say what you "want".
the "want" will cost a $1000+
eaton diff $400
Gears $175
Reluctor gear $100
axles $125 each
master bearing kit $100+
fluids $20
Gasket $5
labor $200
If you have the skills and tools to do the labor great...but setting up gears right is knowledge/experience based
Torque converter...like girls...we all like diffrent ones. 2400-2600 stall with a mild cam, IMHO, is good compromise for street. If it is all about the track go higher. Either way consider a larger external tranny cooler addition
__________________
\'96 BBB 383/T-56
  #10
Old 02-15-2013, 05:17 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
I wouldn't base the condition on the rear diff on the in/out 'play' in the axle shafts alone. There's a certain amount of play in any C-clip style axle setup. Pull the diff cover off and actually inspect the gears. I've never seen a 10-bolt have gear problems unless it was raced or in an application needing a beefier rear end.
__________________
2005 Pontiac GTO
Forum Jump
(c) 2007-2011 Impala SS Forum
