WTH, front swaybar moved sideways ? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Suspension
Thread Tools Display Modes
  #1
Old 02-25-2013, 02:29 PM
Eracer's Avatar
Eracer Eracer is offline
Eracer
Default WTH, front swaybar moved sideways ?
FWB, newly installed:
-Hotchkis springs, BJs, endlinks, shocks.
Now the dang swaybar is literally resting on the frame. Sheesh. Anyone experience this before ?
I forget which bar I have on there, it's a fattie. Could be Addco. Had this happen on the wife's Jeep GC with a new Addco bar. They sent me collars to fix between the bar mounts.
Maybe I should just crowbar the bastard over and see if it stays put.
Edit: oh yeah, I was wondering why my test drive seemed disappointingly rough. Lol. OK, crowbar ain't moving ****. Guess I'll be loosing the mounts and massaging it back with a BFH.
3 pics to follow here -->
passenger side
another passengers
drivers
__________________
The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by menacing it with an endless series of hobgoblins, all of them imaginary.
H. L. Mencken
Old 02-25-2013, 03:06 PM
ProTools4's Avatar
ProTools4 ProTools4 is online now
ProTools4 is an unknown quantity at this point
Send a message via AIM to ProTools4
Default
you need to size the drop links to match the frame drop, *achieved with the coil springs
shorten the swaybar drop links and then things will return to normal
BTW
your on the bumpstops in the picture
__________________
NotoriouSS Tad <-- up to no good!
96' ImpalaSS - Johhny 5 - 7.9 @ 89.07 1.734 - waiting for the DD 9C1 to get out of the way
96' 9C1 - POS / DD / Beater - wiring nightmare in progress~!
67' El Camino - Rosie - 7.9 @ 86.5 1.77 60' on a street tire NA
Click here to check out my EFI tuning Blog!
  #3
Old 02-25-2013, 03:55 PM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is online now
Navy Lifer is an unknown quantity at this point
Default
Also appears that your sway bar has been pushed laterally (from tire contact at full lock) exacerbating the condition--agree with Tad on the end link length.
As for the ride, if you're already on the bump stops when static, ride quality is going to suffer--just for giggles, remove the lower stops and see what that does to the ride. Trim what you're using to get some travel back before contact, and/or try the ZQ8 stops if you're not using them already--you still need to trim them to provide some free travel before the stops come into the picture.
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
  #4
Old 02-25-2013, 04:07 PM
Eracer's Avatar
Eracer
Default
Hi guys.
Yeah, just kissing the bump stops I have ZQ8s in stock from a while back. Maybe I'll try trimming the stockers first, paint it with machinist blue and see if it contacts the frame, assess ride quality and such.
Thx for the end-link advice. At first glance the geometry does not look fubar, i.e. bar ends level with bushings. But definitely looks like a tweak is in order. Found the thread on end link length a while ago, I'll be revisiting that.
My tires have been contacting the sway bar at full steering lock in the past, but never had issue with this swaybar walk-over contacting the frame. Come to think of it, this may have happened when I had the car on jacks and going lock to lock, greasing BJs after install.
EDIT: I just took another good look. I think it's this pos bar I have on there. I bet it's an addco, they suck so bad.
With car steering neutral, the endlinks are tilted towards the front of the car at an ungodly angle. Like 30deg +. It appears the swaybar is not long enough to meet over the control arm links. It does not appear that shortening the links will provide enough bar length to compensate for this.
I could relocate the bar, or get another. I wonder if I still have the stocker...hmmm.
__________________
H. L. Mencken
  #5
Old 02-25-2013, 05:12 PM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
I made spacers out of 1/4 metal stock between the frame and sway bar mounts, no sway bar rubbing.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #6
Old 02-25-2013, 06:10 PM
Eracer's Avatar
Eracer
Default
Thx Pogo, I pondered such a thing but I assure this is not the case. Take a look at the last pic I posted.
The bar is dimensionally INCORRECT.
I bought it many years ago, could be a used piece from a forum member, I do not recall. I recall getting a rear impala bar from lenny however.... Damn Lenny !! Lolz
In the past, as with my wife's jeep, Addco has supplied some ****-awful product. As in dimensionally incorrect. As in, not long enough. Not bad enough to replace but still something to make you go hmmm.
I do also recall hearing the telltale thread on metal scrape when I went lock to lock. Musta been the endlink threads contacting swaybar hole.
This is f'in ridiculous. But I guess I have a few choices - find my old bar, buy a new bar, or relocate this pos. Which may not be a bad thing since the swaybar mount holes in the frame are usually so f'ed up, I can start with some new studs welded on in a different location. Set back an inch or so.
__________________
H. L. Mencken
  #7
Old 03-01-2013, 04:47 PM
Eracer's Avatar
Eracer
Default
Heh. I'm not crazy after all. At least not at this particular moment.
The aftermkt bar is definitely too short. I dashed off to the recycler yesterday and copped a stock bar. Can anyone ID this bar ??
aftermkt bar laying on top of stock 30mm B/D bar, It's a good 3/4" - 1" short of the proper endlink location.
closeup
Caprice bar top, "somesuch" bar bottom.
Caprice bar lying on top of "somsuch" bar.
Cappy on top again, closer.
So, who wants to play "Name That Bar" ??
__________________
H. L. Mencken
  #8
Old 03-01-2013, 05:09 PM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
None of the aftermarket bars is "exactly" identical to the original. Different thicknesses,clearances to the idler arm,slightly different bends,etc,etc...
  #9
Old 03-01-2013, 06:27 PM
Eracer's Avatar
Eracer
Default
Oh yeah, I didn't expect the bar to have the same bend patterns or dimensions as a stocker. Just a little shocked it's short by whole 3/4 - 1".
I take full blame having it on there for the last few years. I obviously never did a thorough enough visual after dropping from the lift, etc. I imagine the recent hotchkis drop exacerbated the issue, making it more apparent. Happy to get it resolved. Sorta sad I lost my big honking bar.
However, I am looking forward to evaluating the new setup (stock bar, hotchkis, konis) vs the old setup (honking bar, stock springs, monroe SS's).
That being said, I'm still just curious if anyone recognizes the bend pattern...
Could it be a generic aftermkt 70's-80's GM fullsize bar ? An addco ? As I mentioned previously, I have a first-gen addco on wife's WK Jeep and it falls short in the same manner. Not quite as bad, but it's disappointing how little they QA'd their ****.
No matter, more than likely I got this bar on the cheap and I ain't crying foul. Unless it's Lenny's fault
__________________
H. L. Mencken
Forum Jump
(c) 2007-2011 Impala SS Forum
