Window Seal - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Exterior
Thread Tools Display Modes
  #1
Old 02-26-2013, 04:37 PM
Yog-Sothoth Yog-Sothoth is offline
Yog-Sothoth
Default Window Seal
1995 Roadmaster, front driver's side window leaks. The upper seal has become folded over, see picture. Can that upper seal still be found new or am I looking at a trip to the junkyard?
Thanks for any help.
Click image for larger version
__________________
1995 Buick Roadmaster
Old 02-26-2013, 05:37 PM
4DoorSS's Avatar
4DoorSS 4DoorSS is offline
4DoorSS is an unknown quantity at this point
Default
That's happened on my car a few times. Just put the window down and get your fingers in there and pull it back out. Kind of hard to describe, but just start where it is normal and keep working it back out til its back in place. Then slowly close the window and make sure it goes into the channel correctly. Unless it is ripped or torn, it should be fine.
__________________
  #3
Old 02-26-2013, 05:54 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
You will probably find yourself unfolding it on a regualr basis. If it got folded once, the cause is still there.
__________________
1991 OCC upgraded LO5, wrapped headers, dual Flowmasters, 3.23 posi, drop spindles & springs, Stainless full moons, 255/60/15 R, 215/70/15 F, Recaros, Nardi/MOMO SW w/QR, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi
For a parts list, check Plenty of good parts
Old mechanic's saying: If it doesn't work, hit it with a hammer...if it still doesn't work, use a bigger hammer...if it breaks, it needed replaced anyway.
  #4
Old 02-26-2013, 06:50 PM
4DoorSS's Avatar
Default
Not sure what caused mine to fold in. Maybe the window catches it as it goes into the channel. Any ideas what causes this to happen and if it can be prevented? It's usually not a problem since I just pull it back in place.
In the 15 years I've owned the car it has happened just a couple of times on each front window. I usually notice it right away and pull it back out and it's fine. It still has the original moldings and it hasn't happened again for quite a while.
__________________
  #5
Old 02-26-2013, 07:19 PM
Fred Kiehl's Avatar
Default
The rubber takes a "set" when held in a position for a period of time. It is difficult to relieve the set without damaging the rubber. Sometimes heat will help to relieve the stress of the set. The only other possibility is to replace the part.
The reason it folds over, is probably a misalignment of the metal track inside of the door. The window may be cocked out a little bit, and it catches the run channel as the window approaches the top. I have not had the issue, so I am not able to give you a definitive answer. It could have happened for the first time before you got the car, and was never adjusted.
__________________
  #6
Old 02-26-2013, 08:07 PM
Yog-Sothoth
Default
Thanks for the replies. Yeah, I've managed to pull it out once, but it's creased so it goes right back in there.
__________________
  #7
Old 02-27-2013, 07:39 AM
4DoorSS's Avatar
Default
Yeah Fred, I was thinking the same thing with the window adjustment. I just have not seen this hapen enough for it to be a concern.
The times it has, I caught it right away and was able to "man-handle" the molding a little and pull it back out without damage. So far so good and its been a while since it happened.
__________________
  #8
Old 02-27-2013, 08:11 AM
Fred Kiehl's Avatar
Default
I would think that the bottom of the track is too far to the interior side of the door, causing the window to point out slightly at the top when closing. The production tolerances of the glass may also allow it to be curved less than necessary to fit the curve of the door. If you get two tolerances out in opposite directions, it can cause issues. So, it could be the glass itself.
__________________
  #9
Old 02-28-2013, 04:33 AM
Mikeceli Mikeceli is offline
Mikeceli is an unknown quantity at this point
Default
Mine did the same thing. I replaced the weathertrip. I need to check the adjustment. The glass catches momentarilly, as it goes up.
__________________
God Bless America!
1996 Impala SS DCM
1996 Impala SS BBB
1995 Buick Roadmaster Sedan
2001 MagRed Corvette Coupe
2000 Ford Excursion 4x4 7.3 Diesel
1979 \"Bandit\" TransAm 403/at
1988 Lincoln Mark VII LSC
1986 Ford F250 6.9 Diesel 4x4
  #10
Old 02-28-2013, 07:00 AM
Yog-Sothoth
Default
Did you find it brand new somewhere or did you have to visit a junkyard to get a replacement?
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
