36lb injectors - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #1
Old 03-20-2013, 04:40 PM
BOWTIEHEAVEN's Avatar
BOWTIEHEAVEN BOWTIEHEAVEN is offline
BOWTIEHEAVEN is on a distinguished road
Default 36lb injectors
So as i posted in a previous thread, I recently purchased a bunch of parts off a buddy's ride.. I am in the process of putting it all together and am about ready to send my pcm off for a tune.. As of now i just learned i have 2 bad injectors on my motor however the intake manifold i just purchased has a set of 36lb injectors in it.. Is there any way i can just use these if i get the pcm tuned for them so i don't have to buy another set of factory size injectors... Some of the parts i am installing are a pair of bbk shorty headers ported and polished lt4 intake manifold ,52mm tb,adjustable fuel pressure regulator, msd ignition box 10.5mm plug wires, like new opti, and a raiss type cai without the heat shield...
Thanks in advanced, Chuckie
__________________
1995 9c1 new best friend
2003 cvpi 40 series stage 2 trick flow sct3 tuner and the lovely j-mod
Old 03-20-2013, 05:10 PM
BALLSS BALLSS is online now
BALLSS is on a distinguished road
Default
for the mods you list you don't "need" the 36 lb injectors. ask your tuner if it is OK to tune for them with your mods as it may be fine but he will need to know if you go with the 36
you can send your stock injectors out to get repaired for around $12-15 per
www.cruzinperformance.com is who I have used before
get a FP gauge so you can accurately set your adjustable FPR to the stock setting or just keep the stock one on. There is no performance upgrade for a adjustable unless your mods warrent it AND your tuner wants a higher than stock FP
__________________
\'96 BBB 383/T-56
  #3
Old 03-20-2013, 05:16 PM
Default
Thanks BALLSS i knew i didnt need them even though i wish i did lol. Just wasnt sure if they could be used since i already had a set sitting around.
__________________
  #4
Old 03-20-2013, 05:19 PM
Leadfoot Leadfoot is offline
Leadfoot is an unknown quantity at this point
Lightbulb
I didn't see LT4 heads as one of your mods. You do know that the intake ports on a stock LT1 head, and the ports on an LT4 intake manifold don't line up exactly?
No performance gain either.
__________________
SSeeya,
Bob Dannelley
95 409-DCM-11.839@115.10-NA,4350#
2011 Caprice PPV-Maggie-11.64 @ 119.68
2014 LTZ Crewcab 4x4-my fu k k in' present to me!!
  #5
Old 03-20-2013, 05:24 PM
Default
Should i not use the intake manifold since it dosnt line up right i knew there wouldnt be a performance gain however i opted to use it because its down right beautiful lol.. Not to mention i got it for next to nothing.
__________________
  #6
Old 03-20-2013, 05:42 PM
Thumbs up
Beauty is in the eye of the beholder. Performance, well that's another thing!
__________________
SSeeya,
Bob Dannelley
  #7
Old 03-20-2013, 06:19 PM
Default
Im taking hat as a yes i can use it still^^^
__________________
  #8
Old 03-20-2013, 07:26 PM
Default
I suggest you either sell the LT4 intake or buy LT 4 heads to go with it. The later will give you little if any performance gain.
Not only does the LT4 manifold not line up with your LT1 heads....it is "ported" to line up with whatever the "ported" LT 4 heads it used to go with.
I sense you will have intake leak problems and may have to see if LT1 intake gaskets work better or LT4 intake gaskets. Sounds like a lot of work just to bolt on a red intake that if it does not leak may even reduce performance with LT1 heads.
Just my $02
__________________
\'96 BBB 383/T-56
  #9
Old 03-20-2013, 07:35 PM
Default
Just my $02
Thanks thats what i needed to know.. by the way the powder coating has been removed and its now polished aluminum
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
