Horsepower and A/C - Page 2 - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #11
Old 05-30-2013, 08:38 PM
Jeff Green Jeff Green is offline
Jeff Green is an unknown quantity at this point
Default
Originally Posted by GuillaumeC View Post
They don't ask you to turn it off when water drips on the track?
I built a water tank that fits in the space behind the passenger side wheel well. Attached a hose from the 90 degree elbow and run it to the tank. The tank has a valve in the bottom of it so I just drain it after each pass.
And the track guys at the starting line never know I have the AC on because it's not leaking on their track. And if your on the street then you just leave the valve open on the tank.
__________________
LTX Aluminum LT1 block engine
Most HP from an OBD1, 1400 plus horse power
Fastest 4L60E
Fastest Impala with everything still in it, 4520 pounds no weight taken out. 9's in the 150"s
Old 05-31-2013, 01:23 AM
ProTools4's Avatar
ProTools4 ProTools4 is offline
ProTools4 is an unknown quantity at this point
Send a message via AIM to ProTools4
Default
on all my recent LT1 tunes I shut off the AC clutch at 50-60% Throttle
then when you back out of the throttle it kick back in all on it's own
stock is 95%
on LS1/2/3/6/7 ect you get more logic than just TPS on off:
RPM Disable
RPM ReEnable
TPS Disable
TPS ReEnable
__________________
NotoriouSS Tad
96' ImpalaSS - Johhny 5 - 7.9 @ 89.07 1.734 - sshhhhh......
96' 9C1 - POS / surf sedan / Beater - traps 103MPH / 29MPG freeway~
67' El Camino - Rosie - 7.9 @ 86.5 1.77 60' on a street tire NA
15' Cruze 2.0L TD MPG machine
  #13
Old 05-31-2013, 01:44 AM
ProTools4's Avatar
Default
if the AC clutch is on and stays on as the Engine spins up it will be fine
..as long as the belt stay on track...
But..
having the clutch apply at high RPM can immediate lead to compressor or clutch death
the clutch basically drops on to the spinning pulley from zero RPM!!!
a 6K RPM Delta clutch drop is killer for just about any kind of consumer style clutch drive line or otherwise
__________________
NotoriouSS Tad
  #14
Old 05-31-2013, 09:55 AM
Default
But..
You are dead on!! The last part I have in my setup to make this work is the clutch wire runs to a relay that is controlled by an RPM window. I have it set so it will kick out the clutch at 3000 RPM's and above. It's needed because when I let off the gas at the end of a pass the engine is still spinning close to 7000 RPM's and you don't want the clutch to go live spinning that hard. For just driving around the car never see's anything over 3k so the AC stays on.
And with the TPS tables it cuts the clutch out as soon as I leave the line because of the 100% reading.
So here is how I see it. Removing your AC will not even get you a tenth of a second at the track. So is not have AC worth that to you? And a setup like this is totally automatic, you don't have to do anything so you can't screw it up. The only mistake you can make is forgetting to drain the tank after each pass or forgetting to leave the tank open when you're just driving it on the street.
Just remember, if you're runnning against me at the track, I'm in AC the whole time
__________________
Fastest 4L60E
  #15
Old 05-31-2013, 10:26 AM
The Fooser Guy's Avatar
The Fooser Guy The Fooser Guy is offline
The Fooser Guy is an unknown quantity at this point
Wink or...
... 'just' drop this between the frame rails (you may have to move them over a bit) and you won't have room for A/C - so it renders the point moot.
(sorry, it was just too good a discussion up to this point.)
__________________
The Fooser Guy
"Diagonally parked in a parallel universe."
Originally Posted by thebigbadWOLF View Post
Tested a coil by listening to MR.WOODS... ****ing coil WORKS just fine.... ass hole
'96 SOB Imp, 'Built' 355 LT-1, 3200 Street Edge, stage-3 4L60E, Unlimited drive shaft, 'bulletproof' 3.90's, Hydra intake, CIA headers, CIA 570 CFM cats, Pypes X-pipe, Dynomax VT's, dumped, Nitto 555's (255/70/15 ), Bilsteins, brake bolt mods, externally stock appearance.
  #16
Old 05-31-2013, 12:59 PM
Default
Why not just hang a window AC unit from a house in one of the back windows and power it with a a/c converter
Somewhere I have a picture of an old beater that someone did that.
__________________
Fastest 4L60E
  #17
Old 05-31-2013, 01:58 PM
KW Baraka's Avatar
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka has a little shameless behaviour in the past
Default
.....Yeah; I've seen a picture like that.....may be the same picture. I LOL'ed real good ......
KW
__________________
1996 BBB SS, 398ci Solid Roller LT4
1995 DCM SS, Heads/Cam LS3
2014 Chevy SS; 429ci LS3 -- 508HP, 455TQ @ the wheels....track results pending
  #18
Old 05-31-2013, 03:35 PM
91ss's Avatar
91ss 91ss is offline
91ss is on a distinguished road
Default
stock is 95%
RPM Disable
RPM ReEnable
TPS Disable
TPS ReEnable
Just one thing to watch for, if the compressor is not 'off' long enough, it's a hard hit on the restart. Much like house ac's now that typical 3 minute timer. It ensures all the liquid refrigerant has evaporated. Don't know if the ecu has a built in delay for the restart. I don't recall seeing such in the definition file.
It may warrant having it high enough so it doesn't get constantly hammered by restarts.
  #19
Old 05-31-2013, 08:17 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is on a distinguished road
Default
When the system is properly charged and it is in good health, there should be no liquid refridgerant at the compressor at all. It should only be a liquid as it leaves the condensor on its way to the orafice tube and then again in the accumulator. Cycling a clutch too often, does wear out the clutch itself though.
Chris
__________________
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
  #20
Old 05-31-2013, 11:49 PM
91ss's Avatar
Default
Not saying liquid at the compressor but in the condenser. Pressure will rise rapidly as the 'empty' space in front of it can be greatly reduced. It's a spike compared to normal running state.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
