dirty dingo ls mounts - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #1
Old 11-03-2013, 05:23 PM
96slowss's Avatar
96slowss 96slowss is offline
96slowss is on a distinguished road
Send a message via AIM to 96slowss Send a message via Yahoo to 96slowss
Default dirty dingo ls mounts
anyone run the adjustable dirty dingo ls motor plates in a b body yet?? about to order a set for my ls swap
__________________
BOSTON INC PROSPECT CHAPTER
1996 bbb impala ss- k&n intake,afterburner long tubes,catless,flowmaster 40s, built 4l60e,shift kit, 3200 stall, locker, 4.10's, 2" glassteck cowl hood,billet insert,tinted tails and headlights, 20% tint, eibach springs,belltech shocks, painted toyoya 1g3 gun metal grey. sitting on black ss wheels for now, all black interior,
-5.3 lsx turbo build in the works-
Old 11-03-2013, 05:36 PM
95wagon's Avatar
95wagon 95wagon is offline
95wagon is an unknown quantity at this point
Default
I have not but , honestly, what is the point?
You can run simple plate adapters between the factor engine brackets ( use two lefts to get rid of the goofy upside down LT1 Specific RH) and let the factory mounts slide on the frame to find their new home before drilling new holes.
If you can drill a 3/8 hole, you can put the engine anywhere you want and not have the universal sliding "thing"
__________________
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #3
Old 11-03-2013, 05:41 PM
96slowss's Avatar
Default
ya. that was the plan at first. is that y the pass side mount sits at a weird angle?
__________________
  #4
Old 11-03-2013, 06:14 PM
95wagon's Avatar
Default
Compared to a regular SB or BB chev, the LT1 has the RH mount set back to give room for the AC position on the LT1
This is done with an additional mount boss on the block and a bracket that looks like the normal bracket upside down (but isn't)
Moving both mounts back equidistant from the bell housing and about the same spacing as the LS bosses flat makes sense and also makes the "bending motion" between the block and trans about the same as an LS production setup.
Functional, measurable difference, maybe not.
If you do go the flat adapter plate route , you will have to clearance the lumps on the factory brackets so they will sit flat on the plates
__________________
The First
12.06@ 118.4
LS7 T56 drag video
My Wagon
My W-31 Cutlass
  #5
Old 11-04-2013, 05:31 PM
96slowss's Avatar
Default
thanks for the info! I think I might end up just making my own mounts like u did
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
