I just bought an 08 impala SS that wouldn't crank. It also has the following issues, which the previous owner said all occurred at once:
1. Car doesn't come out of park without pressing in the button underneath the shifter cover
2. Key doesn't come out of ignition unless you press the button on the bottom of the ignition switch.
3. Gear selection screen doesn't show the current gear, using a scan tool shows that the car thinks its in 3rd gear.
4. Windows, door locks, steering wheel controls, and dome light do not work
5. Blinkers, hazards, and high beams do not work (regular headlights do)
I've done some diagnostics and established that I have good power and ground to the BCM including ignition voltage. I also have ~60 ohms resistance between the high and low CAN wires on the OBDII connector with all modules plugged in and the battery disconnected, and 120 ohms with any/all of the modules unplugged.
I'm really having trouble finding information on how to diagnose this issue. I'm unable to find pinouts for this car's TCM connector to check its voltage properly, but it does have 12v at the pink wire and ground at the black wire.
I believe I have a bad BCM. The scan tool says there's no communication with the BCM when I try to look at it's data display, but I'm not sure what I can do to further diagnose this.
The previous owner said all this happened after the battery died one time and he put a new battery in it. I'm thinking maybe he got the wires crossed and shorted the BCM or one of the other computers? I did get the car to crank by tripping the starter relay but have no fuel or fire.
Any help or feedback is greatly appreciated!
