Either of the press-in balljoints can be replaced without removing the arm using OTC 7039 ball joint service set or equivalent.
I looked into ball joint sizes a while back. Something many people don't realize is that the sizes that are commonly used to ID the ball joints (9/16", 5/8" and 11/16") refer to the theread size of the nut, NOT the actual ball stud.
Since we are talking about the balljoint breaking, the failure mode is called shear and resistance to failure depends directly on cross sectional area of the ball stud. Note that the area is proportional to radius squared.
Here are the major (larger end of the tapered hole) and minor diameters from Moog tech line for the 3 ball joints:
Moog____Nut___Major_Minor_Major_+Area_____+Area
PN______Size___Diam._Diam._Area__from6145__from6141
K6145T__9/16__.786__.628__.485__n/a_______n/a
K6141T__5/8___.825__.668__.535__+10%______n/a
K-727___11/16_.891__.749__.624__+29%______+17%
Note that these are diameters of the ball stud right at the spindle surface. The ball stud breaking due to hard impact is going to happen at the surface of the spindle or some distance away from the spindle surface. I have the ball stud dimesions further away from the spindle written written down somewhere, but I canot find them right now. I recall that the same trend shown above held.
Note that the 5/8" ball joint is only about 10% stronger than the 9/16" ball joint.
The 11/16" ball joint is 29% stronger than the 9/16" and 17% stronger than the 5/8".
I came to the following conclusions:
1) The 10% increase in area from 9/16" does not make the 5/8" balljoints an "upgrade" worth doing. ZIP, flame suit on!
2) The 29% increase for the K-727 would qualify as an upgrade, but it is not needed as long you inspect the balljoints periodiacally and you don't plan to hit curbs during the getaway.
Just like Gerry, I am convinced that failures ouside of accidents result from the ball stud flopping around in a spindle hole that has worn loose.
Even so, I still plan to eventually make tubular arms that allow me to use a taller spinle, bigger brakes and are longer for a few reasons one of which is to allow me to use ZR1 or other vette style wheels (cheap, large diam, good quality & not bad looking) with more backspacing, 11/16" ball joints, and maybe coil-overs also. Maybe one of these years...
Tim
