No, you need LT-1 specific stat. -reverse flow cooling system-. Hypertech 1008 is one. There is another brand that actually makes the Hypertech one and markets the same unit at a cheaper price. Someone will have that info. There is no pro or con about needing GenII specific.
No, a standard SBC thermostat will not work properly in an LT1/4 or L99 engine. You have to go with one that is proper for the engine commonly available under the Hypertech brand and possibly a few others. The standard SBC thermostat will not work because of the different flow patterns of the LT1 engine. Also the LT1 thermostat uses an o-ring around the thermostat instead of the gasket of the standard SBC engines. - Peter
Anyone want to chime in on the other 160 stat? $25 + for the Hypertech seems a little .........hyper?
I found it.
4216. Motorad brand.
Should be the same as the Hypertech 1008.
I found it.
i think this is the one thats in mine, it def says motorad can remember the numbers though
Thanks for the info. Looks like they changed the P/N though. MotoRad 307-160 or 7307-160 for Fail Safe type. Autozone, O'Reillys, etc.
http://www.motoradusa.com/
