D
Look at what I accidentally stumbled across :eek:
Best ¼ mile performance to date:
10.59 seconds @ 127 mph
This 1989 Chevrolet Caprice 4-door started its service with the Phoenix Police Department on June 19, 1989. Instead of 'retiring' the car after 107,175 miles, Detective Gary Whipp, Officer John Knajdi and City Mechanic Mike Scott developed a different and better idea. They recycled and rebuilt this vehicle into the fastest REAL police car in Arizona, 'Blue by You'!
_________________________________________________
Found here
http://www.phoenix.gov/police/race.html
D
Below is a list of specific items the team has need for.
Item
Description
Cost
Sponsored By:
Shocks
QA1 Hal Adjustable shock (front/rear)
$600.00
Phoenix Police Athletic Club
Exhaust System
Quad-1 headers w/Cermachrome..2 Random Tech 2.5” converters, gaskets, header bolts, nuts, washers.
$1390.00
Drive Shaft Safety Loop
The drive shaft safety loop mounts in the stock location and will accommodate up to a 5" diameter drive shaft. Grade 8 Mounting hardware is included.
$75.95
Tomahawk Village Block Watch (800)
Cross Member
4L60 E Cross member
$159.00
Phoenix Police Museum
Body Bushings
Complete Polygraphite Body Mount Bushing Kit
$145.00
Paradise Valley Police Dept.
Engine- Pushrods
Hardened LT1 Pushrods, 7.200 length
$26.00
NAILEM- Ms. Donna Neill
Rear Differential Bushings
Polygraphite Differential Bushing Kit
$102.00
Battery
Optima Red Top Automotive 12V Starting Battery with 720 Cold Cranking Amps
$120.00
Fuel Rails
Stock Fuel Rails
$50.00
Amigo Block Watch Group-800
Intake Manifold
Stock GM Fuel Injection intake Manifold
$100.00
Mrs. Pat Williams
Rear Differential lube
Differential additive
$10.00
Head-valve seals
LT1 Blue Band Value Seals
$29.97
Engine- Rocker Studs
Comp Cams 7/16 Rocker Stud Set
$35.97
Engine- spring kit-heads
612/613 LT1 Spring Kit w/locks & retainers
$91.90
Dorrance Family Foundation
Engine- Gasket Set
GM Head gaskets, timing cover, exhaust
$138.95
Rear Differential Master Overhaul Kit
Includes mini-install kit, large journal carrier bearing, and adjustable shims, axel bearings and seals
$145.00
Water Pump
Meziere Heavy Duty Electric Water Pump
$185.00
Alternator
Rebuilder service plus stock alternator
$187.00
Heads- valves
Stainless Steel intake & exhaust valves
$207.52
Labor
Shop labor to assemble engine
$210.00
Cold Air Intake System
Complete intake kit with Chromex ceramic coating and MAF sensor in orig location
$229.00
Heads
Stock Iron Heads
$250.00
Fuel Injectors
30# SVO fuel injectors
$279.00
Engine- Cam
Comp Cams 1.6 Roller Rocker, NSA 7/16 stud
$288.00
Front End Kit
Performance Polygraphite Super Front End Kit
$339.00
Freight
Freight and Handling charges for complete engine & accessories
$450.00
Throttle Body
Arizona Speed and Marine 58mm Throttle Body 1993-1997 LT1 F-body
$469.97
Rear Differential
Eaton Posi differential (SuperBrute w/ 400# springs) for street & Strip applications, plus 3.73 gears ($175.00)
$540.00
Heads- Machine work
Auburn Auto Machine service for LT1 iron heads: machine, port, surface, 3 angle valve job plus install of valves, seats, seals, studs, springs, etc. Port Match intake manifold and head ports
$748.00
Engine Coating
Ceramic and thermal dispersant coating on misc. engine parts- heat barrier
$850.00
Engine peripherals
Opti-spark, knock sensors, oil pressure sender, Map sensor, thermostat, vacuume hoses, shipping
$871.00
Exhaust
Complete Spintech 2.5” stainless exhaust system w/sportsman street x1 mufflers
$1,019.95
Headers
Quad-1 headers w/Chromex coating
$1,190.00
Transmission
4l60E Street/Strip Transmission 1993-1996
$1695.00
Paint
Performance Specialty will perform all repair and paint duties applying a basecoat/clear coat show room finish
$2800.00
Engine
Golen 385 LT1 Short Block
$3,624.00
I know an the mods list is pretty basic for them to ge that time too :eek:
R
Originally posted by Dragon9c1:
The 1989 Chevrolet Caprice 4-door started its service with the Phoenix Police Department on June 19, 1989 after 107,175 miles.
Found here
I understand this was a quote from the other site. Someone over there needs to learn how to proofread though... The car is a 1989 which started its service in 1989 with 107,175 miles??? I'd assume that they meant it retired with 107,175 miles.
D
Lol yeah I was didn't notice it either :D , I was just paying attention to the pics and part of what it was saying
D
My orig. post has been edited to show the correction that was made on the web-site I posted, after I recieved a friendly heads up email from Officer/Driver Chuck Williams..
Deffinately a great site and he also informed me that not only are they preparing a new car that not will see strip duty but also still in-service
, he is also a fellow B-body owner off-duty as well(a 96 BBB)
