Worked on the parking brake Friday PM . The petal assembly was some what rusty . I sprayed WD40 on the " pawl " that retains the petal in the down position , when you depress it . Got that to working and put the trim pieces back on .
Started cutting out , on the test drive , if I gave it very much gas .
45 mph was about all it would do , w/o cutting out .
I am inclined to think it is not getting enough gas & leaning out ? ( Could also be a problem with spark , but I do not think so . )
Hope to check the Throttle Position Sensor , first , Saturday AM .
God bless
Wyr
This AM , the Caprice ran fine , with and with out the TPS connector plugged into the TPS .
God bless
Wyr
