Hello,
I am selling a Turbo Technologies Impala SS turbo kit. I purchased this around October 2015 with plans to install it on my car but I have decided to go a different route. The following items are included:
1. Set of 8 .030 over Wiseco Forged Pistons, -.20CC Forced Induction application. Less than 1,000 miles. SpeedPro File fit rings. .28” end gap
2. Set of 8 Accell DFI 40 lb injectors, less than 1,000 miles.
3. Turbo Technology turbo kit, complete including turbo, manifold, wastegate, intercooler, exhaust manifolds with all down pipes. You will need some minor clamps and brass fittings that can be purchased at your local hardware store. Turbo is included. I will have to get the specs and post them later- it is whatever turbo that came with these kits originally. I didn't pay any attention to it because when I was planning to use the kit I was going to go to a larger turbo. The “Hot” side pipes are ceramic coated. Coated from Jet Hot, and is their 2000 degree black coating. Although the pipes look like the cold side they are actually high temp ceramic coated. The cold side is cast aluminum and powder coated black wrinkle (coated by Noble Coating out of Peotone IL)
Asking $2000 with pistons and injectors.
