OK all posted this on EBAY starting January 7th.
Time to give to a collector or b-body guy to take it to the next level.
$11,500.00 Car Only.
$16,500.00 for everything.
Email: [email protected]
Cell: 301-512-8034
1994 CustomizedCaprice Wagon (Nicknamed the SSuperwagon)
Time to sell the SSuperWagon. Don’twant to sell been a great vehicle that few cars can fill.
Time is getting moreprecious with projects a growing business.
I also Referee Soccer, Dragrace a1995 Impala SS (IHRA Stock Eliminator), restoring a 1969 Impala and a wife witha lot of honeydooes.
Had for almost 10 years, purchased from Jason Boyer whobought it from another B-Body owner.
They built the bones from a Woody andcreated a SS version.
Removed the wood, welded the holes up and added a nicefiberglass hood.
They did it right and always gets a good look by other carnuts.
Fresh repaint two years ago, repaired minor rust issues, added new carpet andheadliner.
Anytime the car needed a new part it got it.
Engine has less than240,000 miles set up for Heavy Duty Towing with Electric Brake Controller,Class 3 Hitch.
BODY: New paint two years ago,Fiberglass hood, new Windshield, SS Wheels with Nitto’s.
On car 275/50/17 with10,000 miles plus set of four new 255/50/17’s on SS wheels.
TOWING: ClassThree Hitch, Electric Brake Controller with 7 way trailer connector, set up totow 7000+ lbs, car trailer, tools and passengers.
INTERIOR: Z28 Cluster, New Headliner,New carpet, rebuilt front Seat Belts (Racing RED), Airbag Gauge inside Ashtray.
ENGINE: Recent service with new OptiSparc, Plugs, Wires, rebuilt LS1Injectors, new O2 Sensors,
1.6 Roller Tip Rockers, 87 PCMforLess Tune. New Borla H-Pipeinto stock resonators.
Regular oil Change. Does not burn oil and just passedMaryland Emissions with flying colors.
Home Depot Intake.
TRANSMISSION: Recent Rebuilt Fourcade 4l60E transmission with TowingConverter.
SUSPENSION: Tahoe Rear Springs, Airbags, Airbag pump.
Rebuilt Rear reinforced for racing with new Bearings, Auburn Posi, 3.08 gears, Moser Axles, ARP Studs, Metco Lower Arms, rearSS Roll bar.
Front has Eiback front springs, New Steering Box,Center Links and Tie Rod Ends, Jeep Steering Arm.
BRAKES: 3 years ago new front Hawk Pads, Calipers, Rotors.
Recent new ABSController (expensive).
Going to rebuild rear brakes with new parts justbecause.
COOLING SYSTEM: New Radiator, Water Pump, Thermostat,Hoses, Reservoir, heater hoses, rehabbed AC Condenser, fresh anti freeze, FlushedHeater Box.
Cold and Hot when you need it.
ENGINE Project Available: SCAT Forged 383 Rotating assembly, GM 1.6Roller Rockers, new Hotcam, Seasoned Block.
Stage IV Pinks Ported and Polished Iron heads with High Flow 2.02/1.60High Flow Valves, Screw in Rocker Studs, Bronze Guides, Howard ElectroPolishedSprings.
REAR Parts Available: N
ew 3.73’s inbox, 2.56 with Open Rear, 4.10s with Eaton Truetrac.
Another Eaton Posi with400 lb springs, 10 bolt Trickflow Rear Differential Cover, ok for sedan willnot fit a wagon because of the gas tank.
Other Parts Available: First Base and Third available, stock exhaustmanifolds, left Catalytic Converter.
Hallo.
I'm wanted/interest:
Power steering gearbox(for L03 TBI) with pitman arm to centerlink.
Prefer not so big or low miles :)
What value for ratio ?
What value for turns lock to lock?
Does it have a slope?
How slope is big? Explain as you can.
Can you advise me in good faith to buy(or not) your gearbox part?
What price for:
1. gearbox.
2. gearbox pump for L03 TBI.
Shipping to:
N Brunswick NJ 08902-3828.
Thank you.
Hallo.
What price for:
1. gearbox.
Shipping to:
Thank you.
Unless otherwise noted.....all parts (including the gear box) listed are installed on the car.
And this is one hell of a car!
KW
