I am moving homes and just don't drive this at all, so no reason to take it with me. I am the second owner.
Photos forth coming.
Been in my garage for near four years.
Stock wheels with Kumho ASX in stock size and almost new Winter 17" Steel wheels with Blizzaks, less than 6,000 on them.
This was my daily driver from the time I bought it with 38k in 2/98.
New level 2 transmission ($1900) with less than 5,000 miles on it.
Replaced Opti, plugs, wires, coil about 10k ago.
SSBC stainless steel front dual piston calipers, new stock rears, Hawk pads all around, SSBC rotors all around about 6,000 (the dual piston calipers will not fit behind 15" rims).
1996 CD deck with working VSS.
Upgraded ECM.
AIR pump deleted.
ORIGINAL. Stealth Ram Intake (orignal plumbing included with purchase).
I have a Buick frame brace still wrapped.
METCO upper/lower rear control arms.
F-body from sway bar and the original big solid rear bar (wow, I can't remember the guy's name who sold them before everyone else jumped on the band wagon).
Red SSLED bowtie with on/off switch.
Antenna switch.
Alternator and starter replaced less than 10k ago (gotta love lifetime warranty...)
New radiator about 20k ago.
New battery about a year ago.
Things I know need fixed.
AC needs recharged (leaked out while sitting in garage)
Top dash pad has crack.
Both front seat bottoms need replaced. All other seat leather is good.
Paint is worn and has some chips.
Surface rust on frame and inside parts of engine bay.
Was in two minor accidents back in the early 2000's. Professionally repaired.
I have some spare parts too, included.
Will sell only local to Ohio.
Contact me via PM or
timothy dot R dot Lynch @ gmail . Com
Geez Tim, IDK when you have to move but dam I'm sure you thought of stripping easily sellable parts for more than the 2 grand! It looks like you got good use outta the beast, so maybe do the donate/deduct thing - likely for far more than your asking price.
Running?
Does it run ok, without a Check Engine Light?
I need a daily driver, while I drop a new motor in my other SS.
This seems to fit the bill.
Just turn around and sell it after I am done.
