ready to do sumptin else so the ole girl is up for sale. 16?,000 miles young on chassis and engine.
focuztech tri-y headers, cat deletes, pipes x-pipe, magna flow 2.5"
RAISS ram air, camaro 3.5" maf, 52mm tb, brian herter 87 tune, LT4 knock module, mallory 685, magnecore wires
stage 2.5 4L60E by Walts transmissions, edge 2800 stall, 3.73 gears, eaton posi
GMPP 1.6 RR's, comp 26915 beehives
Racetronix walbro fuel pump
wet nitrous kit
mike harris light weight front bumper support
mike harris tubular trans crossmember
clear image safety loop
$5000 OBO
the a/c is off the car but still have lines, condenser, canister, compressor. the fuel gauge don't work cause guy i had put racetronix kit in didn't listen and swap plugs aound then threw old pump away. rear chrome trim on tailgate is gone. interior shows wear. also has air bags and trailer hitch.
for $8500 firm i will let everything wagon related i have go with. four spare window, rear hatch glass, forged 383, spare 96 lt1 and trans, two sets of stock tires. set not pictured are 235/75s with about 500 miles. never ran cause they weigh more than the 225s you see in pics. also have 20" boss 304's with tires less than a 1000 miles. one is cracked from wife hitting pothole. got mad and been in basement for last two years. here are specs on 383
these parts are all used
Eagle forged crank/rods/srp pistons in two bolt block, ported AFR190's back from shop with new springs and hardware, comp stainless hi-tech rockers, AFR hydra-rev kit, moly pushrods
these parts are all new
crane billet cam, gm lifters, svo 30# injectors, bbk 58mm throttle body, delco opti, msd cap/rotor, aeromotive fuel pressure regulator, arp head bolts, melling select pump and pick-up, fel-pro 1054 head gaskets, fel-pro intake gaskets, fel-pro assembly gasket set,
bumpity
thanks wood. i've had a blast with it but time for sumptin different
