1995 Impala SS, 92,000 mile, Green Gray, 2 owners, first owner was my 50 year old mother until 2003. The car was parked in 2003 until I got the car in 2009. No hit body. Original paint and original panels.
Below is a list of every thing that has been done to the car since 2009.
Every maint type item was an AC Delco replacement part.
I have 5,200.00 in parts that I have installed on this car
I am/was a professional mechanic ASE & ICAR certified.
I have every receipt since the car was brand new including the window sticker.
I have ALL the parts to return the car to 100% stock - including 2 set of Cats - 1 set of rear DeCarbon shocks NIB and both Steath Bolt mod not installed yet. - all go with the car.
Car is very clean and very well taken care of.
Serious buyers only.
More photos upon request.
Chris
$9,500.00
Battery, Silver Stars Bulbs, Hood Cable, Turn Signal Bulbs, Washer Bottle, W.Washer Pump, Clear Turn Signals, Tires – Yokohama
Mount & Balance
Stems
Alignment
Exhaust - - Gaskets - 2, Stud Kit - Exhaust, Export Pipes, Bosch O2 Sensors (2), Pypes Exhaust System, SS Band Clamps
Fuel Filter
Removed Oil Cooler, GM Oil Filter Adapter, Oil Filter Adapter Plug, Oil Filter Adapter Bolts
Trans Service Kit, Fluid, Drain kit
Replaced Battery Tray with a black powdercoated one.
Air Pump Disconnect
Install Manifold Plugs
Throttle Body Coolant Bypass
Replaced PCV
Replaced PCV hoses
Replaced Chin Spoilers
Replace AC Compressor AC Delco, Replaced AC Rec Drier, Replace Orifice Tube, AC Service, PAG 150 oil, Oring Kit
Replace Front Shocks - Bilstein
Rear Diff Service Mobil 1 75w90, Posi Additive, Rear End cover, Gasket, Bolts
Replaced EGR GM, Replaced EGR Solenoid GM, Replaced Belt Tensioner GM, Replaced Engine Belt
Installed MSD coil
Installed AC Delco Ignition Module
Removed AIR pump
Replaced Water pump bolts SS Hardware Kit, Replaced Flow Valve - GM, Replaced Tee - Heater - GM, Coolant hose - GM, Replaced Dist Seal, , Replaced Crank Seal, Replaced WP Drive seals, Replaced Dist Drive Seals, Replaced Opti Seal, Opti harness, Replaced Coolant hose Clamps, TB Hardware Kit
Replaced Coolant Bottle, MSD Wire set, MSD Wire Markers, MSD Wire separator Set, CAI, Trick Flow Elbow, Water Pump Assy - GM, Opti Assy
NGK Plugs
Coolant Temp Sensor, TPS, TB Gasket Kit
Harmonic Balancer
Goodyear Hose Kit
52mm Throttle body
Radiator Support cover
Re-tune ECM
Hotchkis tie rod, idler arm and center link kit
Garys - Postive and Negative battery wire kit
Deposit received - pending Sale.
Say it ain't so Chris!!!
I'll be sorry to see it go...I hope you're not leaving the B-body game altogether!
One thing for sure...who ever buys the car is getting one clean machine!
Good luck man!
I think you'll be seeing it around, Matt ;)
Sean
Nice!!
Good luck man!
I hope not.
I would love to keep it but some of lifes events take over.
I also am selling my 9,000 mile 03 Silverado.
I would like to get a wagon and "SS" it
I have always wanted to do that.
I am sure your will see the car "around"
It is staying on the forum.
Nice! I like where this thread is going!
I hope Sean gets it...
Good luck with the sale of that sweet pickup too!
